Also
Does any body know what intakes will fit an '82 3.0L for the EFI conversion?
3.2 3.3 |
Almost Banned Once
I've seen it done with a 3.2 manifold but he was using the SDS standalone EFI.
http://www.sdsefi.com/ |
Almost Banned Once
The 3.2 manifold fits but it is not a perfect fit. The intake ports on the 3.0 heads are shaped to fit the CIS injectors while the ports on the 3.2 are shaped to fit the electronic injectors. Most people hog out the port on the 3.0 heads to fit the 3.2 manifold. I elected to just swap out to 3.2 heads for a perfect match. Also, I used megasquirt (MS-II) similar to the Tbitz setup.
Steve Sapere aude 1983 3.4L 911SC turbo. Sold |
Wer bremst verliert
The alu 3.2 intake on 3.0 heads leaves a narrow manifold face on one side. Using teh 3.2 insulator blocks helps but it is still narrow.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
INJECTORS: $200 FUEL PRESS REGULATOR: $100 WIDE BAND O2 SENSOR: $200 TOTAL COST: $1900 I'd recommend the WBO2 sensor. Although it's not necassary as Tony includes a narrow band sensor w/ the kit. I should be ready to fire it up in about 2 weeks.
Kyle 1980 911sc 3.2 Turbo, 930 Trans 2006 BMW 330i 6mt (DD) |
