o-ring under cylinder
i am rebuilding my 965 turbo engine,
i recently received some parts from my Porsche dealer they send me Black O-rings to fit under the cylinder.
they were Green that was mounted there, did i get the wrong part?
or have Porsche change in there system?
Old 03-04-2009, 01:51 AM
I believe the (superior) green viton O'ring supercedes the black O'ring atleast in the case of a 964. It would appear your engine was rebuilt in the past as the original black ones from the factory were replaced with green viton.
Old 03-04-2009, 02:29 AM
T77911S's Avatar
how can you be sure the rebuild kits contaain the good O rings? i have read about several people buying kits and then having to get the green O rings
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 03-04-2009, 05:54 AM
You need to buy a premium gasket kit that contains all Viton O-rings & seals instead of the normal silicone or neoprene.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-04-2009, 09:57 AM
any one have the porsche part number on the green o-rings?
Old 03-04-2009, 09:59 AM
i think i have a set send me a pm and ill check tomorrow
Old 03-04-2009, 06:29 PM
the O-rings i have buy is from Porsche center so it is the original parts dealer but they are black not the Viton rings i like to have.
they say that the black rings i have recived is the ones for my turbo engine
there are no other O-rings they say,
Old 03-05-2009, 01:58 AM
T77911S's Avatar
i am doing a top end (valves and rings) on my 3.0 and have been looking for a gasket set that contains all the gaskets,washers that i need, but they dont say what is in them or if they are viton. i have even seen the same pic for upper gasket set and lower gasket set, but not what they contain. i think i am going to call the place i got a lot of my parts for my 914-6 conversion, i tell him what i am doing and have and he sets me up. i have these 2 peice oil tubes, they look like weltmeister, not sure if they had all the parts on them or where to get the thin replacement rings or if i should just get the one peice tubes. i think there is a cir clip missing. it had 3 of the thin O rings. sorry, i feel like i have hi jacked
i had to replace the fuel lien from the pump to the engine. i call this company and they send me the part, it does not fit. i call my other guy and he says straight up, there is an update for your car, you need blah blah blah to make it work.
its like going to lowes, i would like to get everything in one trip, but it never happens. sorry to ramble
RACE CAR:: sold
Old 03-05-2009, 04:07 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Steve is correct: Viton is best. Keep in mind that color is not the determining factor. Viton comes in many colors. I have seen green, black and brown.
The best way to guarantee you get Viton is to order a Wrightwood Racing gasket set w/Viton.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-05-2009, 05:35 AM
T77911S's Avatar
is that available at pelican and does it have EVERYTHING, minus rings for a top end rebuild?
this is what i was looking from pelican
930-100-907-03-M17
RACE CAR:: sold
Old 03-05-2009, 10:51 AM
930-100-907-03-M17
Nossir. You need to order those through a Wrightwood Racing dealer.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 03-05-2009, 04:49 PM
