o-ring under cylinder
i am rebuilding my 965 turbo engine,
i recently received some parts from my Porsche dealer they send me Black O-rings to fit under the cylinder. they were Green that was mounted there, did i get the wrong part? or have Porsche change in there system? |
I believe the (superior) green viton O'ring supercedes the black O'ring atleast in the case of a 964. It would appear your engine was rebuilt in the past as the original black ones from the factory were replaced with green viton.
how can you be sure the rebuild kits contaain the good O rings? i have read about several people buying kits and then having to get the green O rings
You need to buy a premium gasket kit that contains all Viton O-rings & seals instead of the normal silicone or neoprene.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
any one have the porsche part number on the green o-rings?
i think i have a set send me a pm and ill check tomorrow
the O-rings i have buy is from Porsche center so it is the original parts dealer but they are black not the Viton rings i like to have. they say that the black rings i have recived is the ones for my turbo engine there are no other O-rings they say, ![]()
i had to replace the fuel lien from the pump to the engine. i call this company and they send me the part, it does not fit. i call my other guy and he says straight up, there is an update for your car, you need blah blah blah to make it work. its like going to lowes, i would like to get everything in one trip, but it never happens. sorry to ramble
Try not, Do or Do not
The best way to guarantee you get Viton is to order a Wrightwood Racing gasket set w/Viton.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
is that available at pelican and does it have EVERYTHING, minus rings for a top end rebuild?
this is what i was looking from pelican 930-100-907-03-M17
Nossir. You need to order those through a Wrightwood Racing dealer.
