Smart quod bastardus
fredmeister's Avatar
help needed-replacing shift rod coupler bushings
===============HELP ADVICE WANTED=============
I removed the rear tranny shift rod coupler and am trying to replace the plastic bushings that are held in the diecast aluminum housing. I am trying to figure out how to push out the steel pin that is pressed into the splined steel yoke that is captured between these bushings.
I tapped on it hard with a hammer and punch and it don;t budge.
I had researched the forums already with the search feature and cannot find any specific forum post that deals with removing this pin and replacing these particular bushings. I don't have a press at home but a good bench vise and some hand tools.
How do I remove this center pin? Don;t want to break the aluminum coupler housing in the process.
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 05-18-2009, 04:11 PM
It will drive out.
Place it on a socket and drive it through. Use the big Porsche hammer or put it in a vice with a couple sockets, one to drive it into and another to push it through
Watch the oval direction when you install the bushings
Bruce
Old 05-18-2009, 07:27 PM
