Pressure relief bypass sleeve
I'm looking for some machine shops that will re-sleeve the bore for the pressure relief piston and the safety valve. I see that Competition Engineering does it any other shops. Preferred West Coast.
Old 06-01-2009, 10:27 AM
DW SD's Avatar
just curious, why do you need that service? Do you have an oil pressure problem? What are the symptoms? On which Porsche engine?
Did you call Ollie's?
Doug
1971 RSR - interpretation
Old 06-01-2009, 02:41 PM
High oil pressure. 2.7 engine. I was told by German Precision to get another case. Bores are pitted and there is some spring marks in one. Check out my other thread about decaying magnesium.
Old 06-01-2009, 04:52 PM
