kwikt 911's Avatar
911E cam timing specs
While researching cam timing setting specs for my 72 E......... I noticed that 70&71(2.2L) specs show 3.15mm and 72 and 73(2.4L) specs show 2.90mm. Is it because of the slight difference in stroke? Funny thing is both the E cams from different years still carry the same part#. Any idea which is correct???
Kevin
Old 05-29-2009, 02:06 PM
Max Sluiter
Flieger's Avatar
Compression ratio went down for the 2.4 for emissions reasons. The cam timing likely suffered for the same reason.
Old 05-29-2009, 04:10 PM
kwikt 911's Avatar
Thanks! I did set it at 3.15mm a few years ago and it ran very well. Then I set it at 2.90mm and it seemed a little sluggish. Soooo going back to the 3.15mm and I"ll report back this weekend.
Kevin
Old 05-29-2009, 06:27 PM
there were some typo errors is best I could figure when I went through this.
3.15mm is what I went with
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-31-2009, 08:39 AM
kwikt 911's Avatar
Thanks Yep the car FEELS quicker and seems to rev faster with the 3.15mm setting.
Kevin
Old 05-31-2009, 10:37 AM
