911E cam timing specs
While researching cam timing setting specs for my 72 E......... I noticed that 70&71(2.2L) specs show 3.15mm and 72 and 73(2.4L) specs show 2.90mm. Is it because of the slight difference in stroke? Funny thing is both the E cams from different years still carry the same part#. Any idea which is correct???
Kevin |
Max Sluiter
Compression ratio went down for the 2.4 for emissions reasons. The cam timing likely suffered for the same reason.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Thanks! I did set it at 3.15mm a few years ago and it ran very well. Then I set it at 2.90mm and it seemed a little sluggish. Soooo going back to the 3.15mm and I"ll report back this weekend.
Kevin |
there were some typo errors is best I could figure when I went through this.
3.15mm is what I went with
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Yep the car FEELS quicker and seems to rev faster with the 3.15mm setting.Kevin |
