degreeoff1's Avatar
Need cam advice?
OK I need new cams (or at least one) as I ate one with a clogged spray bar.
After talking to a few people I have learned that my current cams were reground and poorly. They were GE 40 profile.
I have a set of 74 CIS cams as cores and a ful set of rockers, what would you all suggest I do to get my girl back up an running on the lesser expensive side?
I have 9.8:1 compression, ported heads and PMO's. I liked the power coming on @ 3-4k but the top end 6500 or so was a wee bit flat.
What grind will give me to 7k and come on around the same 3-4k?
Should I regrind or buy new?
Any good suggestions as where to get the work done?
Thank you
Josh
1972 914-6 in the works.....
2003 Ford E-250 "work horse"
2004 Yamaha V-star Classic 1100 "early mid life crisis"
2005 Scion XB "Gas sipping"
1978 Siedelmann S25 "Ataraxia"
Old 06-13-2009, 05:08 AM
Free minder
Aurel's Avatar
John Dougherty is the person to talk to. Outstanding quality of work and expertise, and he posts on
this board as "camgrinder".
http://drcamshafts.com/
Camgrinder
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 06-13-2009, 07:13 AM
jluetjen's Avatar
I assume that you read this thread that 911st bumped up recently. It contains most of what I learned when trying to research the answer to the same sort of question that you are asking.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 06-13-2009, 05:50 PM
304065's Avatar
74 CIS cams aren't suitable for the regrind
Have John make you some new "mod-solex" cams.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-13-2009, 06:30 PM
degreeoff1's Avatar
thanks guys. I have placed a call to John. The attached thread is in a languge I don't speak very well! But I am reading for the third time and I get somthing each read......
Josh
Old 06-13-2009, 08:04 PM
camgrinder's Avatar
Josh, I got your message and I will give you a call tomorrow. Sounds like the original cams were not GE40 grinds. John Cramers suggestion on the mod-solex ( DC30 ) is a good one. These cams will give you a strong mid range powerband and still pull to 7000 rpm.
You can also fill out this form so I have all the details on your combination,
http://www.drcamshafts.com/caminfo.htm
John Dougherty
Dougherty Racing Cams
Old 06-14-2009, 02:56 PM
