Always learning
3.2 in early 911 conversion
Hi list
I saw a really good thread for this a few months ago but I can't locate it.... Could I trouble one of you for the link?
Cheers
R
Old 06-18-2009, 07:43 PM
E Sully's Avatar
Motronic harness questions on 3.2 conversion,
The 2.4 to 3.2 swap has begun
Old 06-19-2009, 08:10 PM
Thanks for that. There was another one that went into more of the mechanical aspects.... shift rod adjustment, fuel pump etc...
Old 06-19-2009, 11:22 PM
E Sully's Avatar
What would you like to know? What year car do you have? The 3.2 fuel pump uses a lower pressure than the CIS and is mounted by the fuel tank instead of the engine area.
The older 915 trans needs notches cut into the bell for the flywheel sensors and has slightly different gearing but will work fine. No shift rod adjustment. Clutch cable is different for early 915 compared to later one. Wiring is not too difficult to adapt.
You will need the wiring harness and DME mounted under the drivers seat.
There are also minor changes for the heat depending on which year exhaust you use.
Some will jump on you and tell you to do a search, but others will answer questions.
Be patient waiting for replies, but I say don't be afraid to ask if a search doesn't work out for you.
Old 06-20-2009, 03:57 PM
Thanks for the info... I'm putting the 3.2 in a SWB 912. Should be fun!
Do you happen to have a pic of the fuel pump mounting location? I might do a search now.
I did read in a posy on t his topic how someone had to shorten the shift shaft that runs down the middle of the car.
Thanks again
Old 06-20-2009, 06:17 PM
here it is
915 trans into a SWB - step by step conversion
Old 06-21-2009, 03:21 AM
E Sully's Avatar
Glad you found it. I'll try and take a picture of how I mounted my fuel pump. My camera isn't very good.
Old 06-21-2009, 06:12 PM
E Sully's Avatar
I took 2 pieces of sheet metal and rounded them to fit the axle and fuel pump, then I welded them together with a spacer to leave room for the hose clamp.
Old 06-21-2009, 07:03 PM
Always learning
Thanks again for the pic....
Any thoughts re. the diameter for the fuel supply and return lines?
Old 06-23-2009, 05:47 PM
