Ken911's Avatar
What grit to use for lapping the valves
I'm pulling the motor apart in a couple weeks for new pistons and cylinders and to fix some oil leaks. the heads were done 30k miles ago so I planned on just re lapping the valves. what grit of clover lapping compound should I use. I also planned on lapping the cylinders to the heads. The engine is a 3.3 turbo soon to be a 3.4 turbo.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 07-07-2009, 08:09 PM
docrodg's Avatar
Grit depend on the condition of the valves and seats. The worse they are, the coarser you go to begin with. Basically, if you need to go with medium or coarse grits, get the seats and valves just to the point of smooth and even then go to the fine lap compound and give it a little work to make it nice.
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 07-08-2009, 04:58 AM
abit off center
cgarr's Avatar
Lapping is really only to check the fit, it can not be used to remove metal or make a bad seat good again.
______________________
Craig
G2Performance
Old 07-08-2009, 05:26 AM
docrodg's Avatar
It cannot make a badly leaking seat good, but minor pitting/wear can be lapped out. The process removes a small, minuscule, microscopic, tiny little bit of metal (it is basically hand-grinding). A quick fine-lap (just a few spins of the valve) is great way to check on machine-shop regrinds.
Just clean the valve and head about 5 times after you do it to make sure no grit is left.
1968 911S "Leona"
Old 07-08-2009, 07:08 AM
Ken911's Avatar
i know what lapping is i was a machinist in the navy for a very long time. I was just wondering what grit is being used for final lapping on valve seats. These were just done 30k miles ago I was just planning on freshening them up while it was apart.
2019 Silverado 6.2L
Old 07-08-2009, 10:54 AM
Ken911's Avatar
Actually a blue check checks the seal, lapping uses fine grinding compound to make the seating surface fit and not leak.
2019 Silverado 6.2L
Old 07-08-2009, 10:58 AM
304065's Avatar
Don't lap them, leave them alone.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 07-08-2009, 11:53 AM
Navin Johnson
TimT's Avatar
I use the permatex lapping compound then prussian blue to check..
Also found this with a quick search..
Lapmaster
'69 911 GT-5
'75 914 GT-3
and others
Old 07-08-2009, 12:40 PM
if you want some really fine compund, try some JB bore compound from Brownells.
you might even find some more uses for it.
Old 07-08-2009, 02:19 PM
Ken911's Avatar
so it looks like something finer than 320 grit. I have everything from 200 grit to 1000 grit in my haz mat building, with expired shelf life. So looks like i'll try 400 grit clover. If they need anything at all after i inspect them. I am also still debating if i should ceramic coat the chambers. I have got the stuff to do the piston domes havent decided on the heads yet.
2019 Silverado 6.2L
Old 07-08-2009, 02:32 PM
You can lap the face and seat, but that's when both parts are at room temp. What happens when the combustion chamber is supporting exhaust temps of 800ºF? The valve expands a little in size, so does he valve seat, and the room temp contact surfaces no longer coincide.
In addition, most valve face/valve seat angles are ground to provide a 1º interference sealing surface - it creates a point contact. Grinding an impression of this interference point into the face of the valve doesn't make sense.
I vote for Prussian blue to indicate the location of the interference seal on the valve face.
Sherwood
Old 07-08-2009, 02:57 PM
why bother? was it a poor valve job that has excessive leakdown readings?
206 637 4071
Old 07-09-2009, 05:28 AM
Ken911's Avatar
No i do have a lot of blow by pretty sure the rings were toasted. which is why the new pistons and cylinders, I wanted to go to a 3.4 anyway. I just figured if it's apart I might was well freshen it up some if it looks ok. I will blue check them and do a good inspection in any case.
2019 Silverado 6.2L
Old 07-09-2009, 04:31 PM
