What is this bushing?
One more question guys.
I found two of these bushings under my shroud. Not sure how many I should actually have? I'm thinking three total?
I think I lost one or two of them.
Any input would be appreciated.
Thanks,
Leakproof.
Restoring/Rebuilding Yellow Canary '79 911SC
Suspected track car
Old 09-01-2009, 02:43 PM
BURN-BROS's Avatar
I think those are the spacers for the ac bracket support. There should be two. They would mount on the two 6mm studs that are on the passenger side cam tower.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 09-01-2009, 05:02 PM
Indeed, I think I had two to start with. Seeing I have no more a.c. components do you think perhaps I could ignore these upon re-assembly? I thought there were only two!
Thanks,
Leakproof.
Suspected track car
Old 09-01-2009, 05:29 PM
BURN-BROS's Avatar
Sure, remove the two studs in the cam tower and replace them with with the apropriate bolts if you need it to be "factory".
Burnham Performance
Old 09-01-2009, 05:44 PM
Sounds like a plan,
By 2010-2011 I should be at that stage of re -assembly
Thanks, again.
Suspected track car
Old 09-01-2009, 06:16 PM
