3.0 rebuild started. Have a few questions. PICS
Hi everyone. I started my 3.0 tear down the other weekend. All went smoothly till the last flywheel bolt. I attempted to remove it with heat and vice grips, but no dice. In the end I welded a cheap 8mm allen wrench to it. It came out with ease. I have a few questions related to disturbing discoveries found inside the case. All and all the crank and bearings looked great minus the main bearing which had a slight score. It's deep enough that it should be replaced.
Is this normal? It appears to be apart of the thermostat channel.
Piston 2 had a chip at the base. If this still weights out fine then can I use it? No idea how it happen. My guess is it happened sometime during head stud removal.
When I got the motor the chain housings and tensioners were off and i'm guessing at some point the chain got bound. It's just the one tooth, but I have a feeling it should be replaced. Worst case it shears off at some point?
main bearing
cylinders are all in good shape
flywheel bolt removal
Can anyone give me advice on what to do about the cam chain gear, piston, and unusual crater near the thermostat channel?
Matt
85 (early) 944
78 sc targa
"The fool who wades in doubt will float like concrete"
Old 09-24-2009, 08:45 PM
Are the pictures displaying ok?
85 (early) 944
78 sc targa
Old 09-25-2009, 04:55 AM
I can see them... Can't answer any of your other questions, but I can certainly see the pictures.
Its only a matter of time before one of the experts show up. I'm sure one of them will chime in when they can.
Don't Lift... Don't Lift... Don't Lift
'75 Targa in "Arrest Me" Red, 3.0SC ('79) engine, Bilsteins, Turbo Tie-rods, SSIs into 2-1 M&K muffler... and looking for my next upgrade.
Old 09-25-2009, 05:51 AM
mca mca is offline
mca's Avatar
First two pics ... that is normal. I asked the same question during my rebuild. Leave as is.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 09-25-2009, 10:05 AM
Thanks MCA. Thats good news.
I think i'm going to replace the intermediate sprocket regardless considernig it's only $54. Anyone have any idea about the piston?
85 (early) 944
78 sc targa
Old 09-25-2009, 10:10 AM
mca mca is offline
mca's Avatar
I believe that the consensus is that you should replace both IS chain sprockets.
I didn't though ... only replaced one (towards front of engine) because the other one looked brand new. If I could do it over again I would replace both.
If you have a shop replace the sprockets, have them clean out the IS shaft too. Lots of crap came out of mine.
Also, enjoy the journey. It is a blast.
Old 09-25-2009, 10:16 AM
OldTee's Avatar
You might be able to file out the piston but I would replace it. Consider the stresses on the piston during operation you will never know until it comes apart. Replace the gears.
Old Tee
all 911s sold
Old 09-25-2009, 06:14 PM
Would you suggest deglazing the cylinders. They don't seem to have the yellow glaze that everyone talks about. Am I wrong?
85 (early) 944
78 sc targa
Old 09-27-2009, 12:20 PM
Also the cylinders showed no ovalness at all. Though they were slightly under spec in diameter, but still well within spec when it came to piston to cylinder tolerance. Thats the most important part is that the gap between the piston and cylinder is not too great right?
85 (early) 944
78 sc targa
Old 09-27-2009, 12:23 PM
Personally I'd not be afraid to use that sprocket. In fact I usually keep the old chain unless it's worn out. I'd clean up that piston with a file and use it too. The case area is normal. You should check the outside of the case in that area and cover any defects with JB weld. This prevents oil leaks there. The bad news is you have Alusil cylinders. The good news is that many have had success reusing them. Personally if the old rings are in spec I'd keep them. If not then you'll need to go through a deglazing procedure on the cylinders and put in new rings. The most critical measurements are the cylinder to piston clearance and the top ring land clearance. These numbers are in all the books but basically the top ring cannot have more than .004 inches clearance and the piston to cylinder cannot exceed .004 inches either. If you re-use the old rings then you could cheat a little on the top ring number.
Keep in mind that I'm not a professional rebuilder and I mostly work on my and my friends race engines. I try to save money but still get a reliable engine that has good compression and doesn't burn excessive amounts of oil. If you want a "zero time" engine you might need to replace the pistons and cylinders.
-Andy
Old 09-27-2009, 04:47 PM
thanks for all the advice Eagledriver. I'll check the top ring landing clearance next. Can you tell just by looking at the walls which metal it is? These have Mahle 95ZN1W3 stamped on them. I hope they can be reringed. I already pitched the old ones.
85 (early) 944
78 sc targa
Old 09-27-2009, 07:31 PM
11 fins for an sc cylinder means nikasil right? I think I might be in business for reringing these bad boys.
85 (early) 944
78 sc targa
Old 09-27-2009, 08:42 PM
Mahle=Nikasil for SC cylinders.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 09-27-2009, 09:23 PM
I was basing my call on the color of the cylinders. Usually the Nickasil looks much more gold colored and the alusil looks like the picture you showed. Nickasil is magnetic....
-Andy
Old 09-28-2009, 06:39 PM
Look at the pictures in the thread "scotchbriting the cylinders" and you'll see what Nickasil looks like.
-Andy
Old 09-28-2009, 06:43 PM
I'll check to see if they are magnetic or not. I am positive that they have 11 fins and no fin support brace. I read in one of those threads that a 3m 7447 pad should be used which is a 1 grade. The only one I can find locally is a 00 grade (less abrassive). Would this be sufficient for deglazing?
85 (early) 944
78 sc targa
Old 09-30-2009, 08:36 PM
Certified Porscheaholic
777joee's Avatar
Checking cylinders
If can use a very small magnet on a string and bring it close to the inside cylinder wall it should swing over and attach itself to the cylinder wall. If not you lost the lottery and have Alusil not Nikasil cylinders.
That is the sure way to check.
Dave Mitchell
Proud owner of "The Beast"
2010 Intermeccanica Speedster with 100% 1980 Porsche 3.0L power and suspension.
http://photobucket.com/IM-6build http://www.intermeccanica.com/
Old 09-30-2009, 10:42 PM
Hi, How's the crank look on that main? Your using new main bearings I'm sure and your probably all right on the crank (they're so hard) but you've got to look or have the shop check it when it's micropolished. The guys are right that removing and then polishing the nicked area on the piston should be fine, people have been modifying and shortening piston skirts for along time, just make sure there are no cracks and you leave no sharp edges that could become stress risers (that area does see some loads). Ditto on the gear (but prudent advise seems to be to replace). The point made above about clearance is more important than the nick. Tom's right Mahle= Nikasil's for SC's. There's really no "bad" news in the pics.
Signed the "eternal optimist"...LOL
86 White 3.4 Turbo (Salt)
81 Black SC (Pepper)...OK, I know it's corny...LOL
GT-4 911 "Yellowbird II"
"Don't try and sell crazy here....we're all stocked up!" - Jack Nicholson
Old 10-01-2009, 03:05 AM
OldTee's Avatar
Eagledriver and others have a point. Polishing the piston might work, and is low risk. But doing so is on the wrong side of the risk/reward curve. A used piston is maybe $25-50. A destroyed engine priceless. Then there is the nagging thought that the piston is flailing away at 6500rpm just as you exit turn one. There is a cost to that too.
Old Tee
all 911s sold
Old 10-01-2009, 05:52 AM
