Originally Posted by Shoepop View Post
In my experience this is not true if you choose correctly. I have seen and personally experienced way to many MSD failures in the past 10 years. Granted anything can and will fail but the more parts the more prone.
JMHO, but the majority of MSD failures that I've seen were due to installation errors. Its easy to condemn various components but do not discount "Human Factors" as thats truly the biggest variable,.... The key is attention to detail.
I've runs MSD's on our race cars since 1978 and never experienced a problem.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-22-2009, 10:59 AM
120 HP/Liter is all I ask
Hook an MSD 6 AL up to an, unrecommended by MSD for the 6AL, MSD Pro Power coil and you will see the 6Al fail after about an hour of duty, don't ask me how I know this...but I suspect some failures stem from these mistakes.
"It all started when I began looking around and just could not find my dream car. So I decided to build it myself” - Ferry Porsche
Old 11-22-2009, 01:10 PM
Well just to update this, I'm going XDi via Don at EBS. ( Just to say so far, both Don at EBS and Richard at Clewett have been top blokes ).
964 Cams and 98mm Mahle high comp P+C's, twin plug heads and 964 bottom covers.
Hope it all works!!
Db
Old 11-24-2009, 02:49 PM
Jeff Alton's Avatar
What are you using of an intake?
Cheers
www.turn3autosport.com
Old 11-24-2009, 03:26 PM
Hi
Just the std intake set up.
Why do you ask?
Db
Old 11-25-2009, 05:26 AM
Jeff Alton's Avatar
If you were using carbs or ITB's I was going to suggest a larger cam to take advantage of them. But your build looks good!
Cheers
Old 11-25-2009, 07:49 AM
Good, thats reassuring.
Db
Old 11-25-2009, 10:40 AM
MrPerkles's Avatar
Send a message via MSN to MrPerkles
Go Go Bronco,dont forget you have a master engine builder on your side as well
www.facebook.com/pages/Bournville-Frameworks
Old 11-26-2009, 02:09 AM
sp_cs's Avatar
If you're twin plugging, you may as well go 100mm Nickies for a 3.5?
Shirish
1987 Carrera, Granite Green
Old 11-26-2009, 11:17 AM
Not in within budget.
But if you have some you want to donate some ... lol
I do have that set of 98mm Mahle RSR fitment pistons and cylinders in good shape ( I think 8 P's and 9 C's )
if any one out there wants to do a deal I would be interested.
Db
Old 11-27-2009, 12:41 AM
Eye of the Toiger
matty74's Avatar
Originally Posted by longhornchris04 View Post
The "big 3" are:
2 - a dual distributor system - usually modify a 964 distributor for triggering, and run run 2 CDI boxes & an some electronics to control advance (as the 964 has no mechanical advance)
Can I use Megasquirt II to control the advance if I choose option 2 set-up? I want to use 2 x MSD 6AL boxes
http://www.aircooled.com.au
1973 911 RSR clone powered by 77 3.0 turbo
Old 12-28-2009, 01:06 PM
