![]() ![]() I've runs MSD's on our race cars since 1978 and never experienced a problem.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
120 HP/Liter is all I ask
Hook an MSD 6 AL up to an, unrecommended by MSD for the 6AL, MSD Pro Power coil and you will see the 6Al fail after about an hour of duty, don't ask me how I know this...but I suspect some failures stem from these mistakes.
"It all started when I began looking around and just could not find my dream car. So I decided to build it myself” - Ferry Porsche |
Well just to update this, I'm going XDi via Don at EBS. ( Just to say so far, both Don at EBS and Richard at Clewett have been top blokes ).
964 Cams and 98mm Mahle high comp P+C's, twin plug heads and 964 bottom covers. Hope it all works!! Db |
What are you using of an intake?
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Hi
Just the std intake set up. Why do you ask? Db |
If you were using carbs or ITB's I was going to suggest a larger cam to take advantage of them. But your build looks good!
Cheers
Good, thats reassuring.
Db |
Go Go Bronco,dont forget you have a master engine builder on your side as well
www.facebook.com/pages/Bournville-Frameworks |
If you're twin plugging, you may as well go 100mm Nickies for a 3.5?
Shirish 1987 Carrera, Granite Green |
Not in within budget.
But if you have some you want to donate some ... lol I do have that set of 98mm Mahle RSR fitment pistons and cylinders in good shape ( I think 8 P's and 9 C's ) if any one out there wants to do a deal I would be interested. Db Last edited by Bronco; 11-26-2009 at 11:44 PM.. |
Eye of the Toiger
Can I use Megasquirt II to control the advance if I choose option 2 set-up? I want to use 2 x MSD 6AL boxes
http://www.aircooled.com.au 1973 911 RSR clone powered by 77 3.0 turbo |
Thread Tools | |
Rate This Thread | |
