To tired to read back through every thing. Are your pistons brand new or did you get them refurbished?
My pistons are JE 10.5 : 1 with Poly Dyne slip coat on the sides and Poly Dyne thermal coat on the crowns bought new from Pelican. I re-used the Mahle barrels and had Arron de-glaze them. They measured in spec and the clearance worked out to be .018+-. Since this is a budget build, I used off-the-shelf pistons, not custom.
I also had Poly Dyne coat the main bearings with their slip coat that we used on the pistons. I have a good friend who is a race motor machinist and he swears by this mod especially with the fact that the Glyco bearings are not what they used to be. Lindy |
I had the pistons refurbished by Ollie's a while back. I still have not completed the rebuild so maybe ther is still hope for JE. Let me know what you think of them.
I hope that clearance number is really .0018!
-Andy |
Great thread.
Just curious as to what disadvantages there would be to an identical build using small instead of large port SC heads? Would top end suffer? Would low end torque be better? I have a spare 80SC motor that is going in my 914/6 and will be rebuilding it using specs similar to yours, except with smaller port heads as that i what i have. |
I'm not sure what the consequences would be with the later heads, pro or con. I do know that Henry Schmidt has offered the idea that the smaller ports can actually help the motor make more torque. He makes an intake fitting that reduces the intake port size which, as I understand it, helps to speed up the intake velocity filling the cylinder better. I don't know anything more than that.
My experience with motorcycles is that most of the time bigger is better as long as all the other parts of the puzzle support it. Big port heads with a small cam does no good. My motor is not a daily driver but more of a means to destroy rear tires on the weekend. It's my modern day motorcycle with four wheels, you know, the Saturday morning meet up with the guys and try to avoid tickets and deer while finding new limits in our 911s. So in my opinion, the earlier heads will make a few more ponies on top, but I'm sure yours would be a kick in the pants as well. Lindy |
Aaron, will the performance characteristics of a small port, 10:1 3.0 motor be similar to Tom and Lindy's if one use's a DC-30 cam? Should i just port the heads, or do you agree with Henry on the 'Small port more torque' concept? |
I agree with Henry about keeping a conservative port size for a street car. However, one must select a cam that augments port size. If your ports were above 36mm then going to a more aggresive cam profile will give you good results. Typically Henry uses 38mm ports on the 3.0 and 3.2SS with a DC60 cam. The final product is impressive. The DC 30 has some legs on the smaller motors, but think of the DC30 as a "E cammed" type of engine when the displacement gets to 3 liters....YMMV |
1-21-2010 update
Well I finally got some time to start re-assembling the project 911. After a couple of dry runs to test fit the crank in the case and get all the bolts and nuts lined up, I assembled the bottom end. Turns out I had to do it twice anyway. When I tried to turn the crank after torquing everything down, it would turn but only with the use of a ratchet on the pulley bolt. So apart it came to check for problems.
I believe it was two fold; 1) the assembly lube provided in the Pelican kit is very thick and at 35F it made turning the crank difficult and 2) the over-spray from the bearing coating on the back side of the mains may have contributed. I noticed this after I took it all apart and cleaned everything up for re-assembly. There was material that you could feel so I sanded it off with 400 grit wet /dry and all is good. When I re-re-assembled the case, everything was good to go. I could turn the crank with the snout alone and it felt very buttery. Now it was time for the Ps & Cs. Pretty straight forward with the exception of the JE cir clips. Takes some time to get a technique down but definitely more difficult than the stock clips.http://forums.pelicanparts.com/uploa...1264097361.jpg Then it was time for the heads, cam housings and chain boxes. Nothing overly hard about the build so far but that's subject to change as cam timing is next. I've also included photos of a few mock-ups of the carbs and nickel plated fan. http://forums.pelicanparts.com/uploa...1264097409.jpg http://forums.pelicanparts.com/uploa...1264097464.jpg /91+rebuild+2+0011264097546.jpg[/img] http://forums.pelicanparts.com/uploa...1264097628.jpg http://forums.pelicanparts.com/uploa...1264098277.jpg http://forums.pelicanparts.com/uploa...1264098334.jpg http://forums.pelicanparts.com/uploa...1264098481.jpg http://forums.pelicanparts.com/uploa...1264098537.jpg http://forums.pelicanparts.com/uploa...1264098585.jpg So far that's it. More to come..... Lindy |
Looking good!!
Who or how did you get the fan nickel plated? Any shop that does chrome plating could do this? Thanks for the pics and keep them coming.. |
The Nickel was done in Houston and is electro-plated. Be very careful as standard chrome platers dip the fan and housing in acid before they plate and the magnesium will explode! It has to be electro-plated, not dipped.
Lindy |
along with this, posting "good job and thanks for posting" just takes away from what is a great thread. and when a thread gets really long, trying to read throught atta boys and get to the meat, gets old. lets try to keep the threads down to info about the thread. and i mean this in a nice way. yea yea, i know, i added to the clutter, but i wanted to subscribe:D |
On a mobile phone there is no other way to subscribe.
And also, lookin' good! Quote:
Great Thread
Looks Great Lindy !!!
If you aren't running AC I would recommend going to a single belt pulley and pulley half, it saves a couple of pounds and looks great !!! After all your at least saving weight using two clamps rather than three on your air guides. SmileWavy Shane |
Thanks Shane.
I installed the old pulley so I could turn the crank while installing the pistons and cylinders. The pin and hole have some slop so the Z-1 mark is not accurate. I'm going to have to replace it with something. Where do I get a single belt set-up that you mentioned? Lindy |
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/448986-wanted-single-belt-fan-pulley-half-accepts-sc-wrench.html I found the engine pulley locally for 30$. It has the TDC 5deg. 30deg and 35 deg. as well as the other marks. For reference the crank pulley from pelican is: 930-102-028-09-OEM The fan pulley half in pelican is: PEL-RS-PUL2-BLK You should be able to find both used, the diameters for crank and fan pulleys were different for different years but they all mount to the crank the same way, you will just have a different ratio, a smaller crank pulley will save a bit on the HP drag but may not cool as efficiently. A lot of used pulleys that are still out there are warped, if they are on a shelf it is usually for a reason, be careful. SmileWavy |
As with any first time efforts, the learning curve is still on an upward slope. I found out over the weekend that my crank pulley and the Z1 mark are not accurate with actual TDC. I am in the process of timing the cams and after going over the steps in Waynes book and trying to over complicate the whole thing, I realized it's actually very simple. With my GE 60 cams I want 5mm of initial intake valve travel at TDC on #1 & #4. The steps described to get there are confusing to me. Anyway, I was getting exhaust valve interference at TDC. The valve was making slight contact with the top of the piston with the cam set so the intake had 5mm travel at TDC.
This got me thinking and I advanced the cam another 5mm of intake valve lift and everything worked; no contact. The culprit; crank pulley that allowed about 8 degrees of movement because of a loose fitting pin and hole on the pulley. I removed the pulley and installed a degree wheel so I could re-establish true TDC. Turns out that it was off enough to be catastrophic had I not been paying attention. Moral of the story; Make sure your TDC (Z1) value shown on the crank pulley is accurate! |
More to the story: I can't read a dial indicator. I was setting the intake valve at .020" instead of .200" (5 mm) which means the cam wasn't even close to being advanced enough at TDC. This is why the exhaust valve was interfering with the piston. When I finally figured this out, I sat on my stool in my shop and laughed out loud at myself for quite some time. Bone head comes to mind!
Never the less, the crank pulley was still off by more than .375" or about 8 degrees. With the help of a degree wheel, I got the Z1 mark dead nut and we're on our way to the next part of the learning curve. Lindy |
I know the feeling, your happy that you found out you did something wrong but pissed that you wasted so much time, sometimes I look in the mirror and laugh. It is great to read that you are moving ahead.
Make sure you check your compression to ensure the valves are seating, I hate to think that you could have bent a valve but it is possible, I know this from experience. Shane SmileWavy |
what degree wheel setup did you use? was there a specific adaptor?
If you're looking for a degree wheel, this product might work.
http://forums.pelicanparts.com/uploa...1265337221.jpg |
Henry, do you sell those pulleys or have a source? And do you have different sizes available? Lindy was asking about a single pulley set up. SmileWavy
Shane |
These are designed to run your fan at the optimum speed for ducted fan efficiency. We also make a 7075 hard anodized aluminum fan center and pulley to match with our pulley's. The later fan centers make it hard to match engine speed to fan efficiency. http://forums.pelicanparts.com/uploa...1265341336.jpg http://forums.pelicanparts.com/uploa...1265341352.jpg |
"When I finally figured this out, I sat on my stool in my shop and laughed out loud at myself for quite some time. Bone head comes to mind!"
If I might add my 2cents. It takes a secure individual to laugh at oneself while alone in a garage where the dog/cat can hear you and MAYBE the wife/significant other/offspring. But when you display it for the Pelican world to see/hear, that takes a chunk of gonads. You quickly becoming my hero. I hope to attempt your journey soon and am damn glad to have this thread as a guide. Thanks! |
Without the likes of Aaron and Henry, my project would be a total disaster if left to my own means. I understand most things mechanical and am for the most part (other than a short stint at the Honda motorcycle school back in the 70's) self taught. That in itself can be a recipe for failure and I have seen plenty of that with other projects. The key is to stay with it and never give up. I sound like a football coach.
I had a 30' go-fast boat 10 years ago during my first mid-life crisis and I built blown 496 GMs for it. 90 mph for about ten minutes and "BOOM". I had problems getting the fuel and timing sorted. The weird thing was that the motor breaking didn't bother me; actually I looked forward to it. It is amazing how much you learn through trial and error. The biggest difference between the boat and the 911 is that I could replace both motors in the boat for the cost of the one build for the 911. I'm trying to be smarter about it and when dumb-ass things like not reading the dial indicator correctly come up I just have to remind myself why I'm doing this in the first place; because I absolutely love it! Lindy |
EmeryG,
I'll take a few pictures of my degree wheel set-up and post them this weekend. Lindy |
I've been married 3 times and now dating a 24 year old and when I do dumb-ass stuff "I just have to remind myself why I'm doing this in the first place; because I absolutely love it! " :) http://forums.pelicanparts.com/uploa...1265388970.jpg |
Henry,
Now you're going to get me in trouble. My wife (15 years) thinks we're talking cars here. Now when I go out of town and she snoops through my posts shes going to run into this picture! And even though I didn't post it, take it, or enjoy the spoils of it she will blame it on ME! You are a piece of work my friend! Lindy |
Henry, can you please ask her for an opinion on your head studs?
Sorry, couldnt resist :) |
As I've posted so many times before "If it doesn't spin, what's the point?"
Just to respond to an earlier post about "head studs", I will avoid the obvious pun and just say "she thinks I'm a stud". |
Great Henry now Lindy can only post when wifey isnt around. :)
talking about pulleys and then....:eek: |
I wasn't sure just exactly what it was, but I just knew there was something ... ya... something else I knew I liked about Henry.
yep a man after my own heart :D |
Ok re-focus now.....
So this might be a dumb-ass question but that's all right because it's still just a question. Back to pulleys. Has anybody tried cutting the two pulley, pulley in half making it a one pulley, pulley? I am wondering if this could be done then balanced at the machine shop. $150 plus for a pulley seems like money I can spend elsewhere. |
The aluminum pulley offers two benefit cutting a pulley does not. 1 degree increments and lighter weight. At higher RPMs, steel pulleys can easily loosen and distort the dowel pin hole in both crank and pulley. Modifying the cast iron pulley also brings a question of structural integrity into play. |
OK, It's been a while. I washed my digital camera with my favorite sweat shirt and have not been able to take any pictures of the progress. Today the beast lives. Fired it up at 4:35 PM CST this afternoon and it lit right off. I have an oil leak on the left bank that looks to be a rocker shaft but there is a lot of oil coming out. I pulled the valve cover and made sure it had a good seal and tried again but the same thing; oil after about a minute of run time that looks like it's coming from the #1 spark plug area.
I'll look into it in the morning but I did run the motor for about 20 minutes at high idle for the break in thing. I am here to tell you this motor has some snap. It revs instantly and very willingly. It's like a light switch; can't wait to drive it. Anyway, my wife is going to get a new digital camera this weekend and I'll take some shots and post them of the installed motor. Lindy |
Glad you got it going, I got mine going as well. I ended up torquing my rocker shafts tighter than spec.
I am sure you will get the leak sorted, it could also be the can seal but probably the rocker shaft like you suspect. Good luck, Shane SmileWavy |
| All times are GMT -8. The time now is 03:58 AM. |
