Carrerax's Avatar
As much as I dont want to spend the money, I think it is necessary. It is going to push out the completion date a bit though. Luckily Im not in a hurry. After talking to Steve extensively, I have decided to use OEM GT3 bearings also. They are considerable more $ but hopefully worth it in the long run.
1997 C4S stock...ish
1970 911T Restored Hot Rod....Sold
http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html
Old 01-17-2010, 05:32 AM
175K911's Avatar
Originally Posted by Carrerax View Post
Greg, I just wanted to thank you for the encouragement. I split my case last night. It looked similar to yours. The intermediates were the same. My mains look great but the thrust bearings are a bit more worn. My rod bearings have a bit of wear so I am just going to replace all the bearings while Im in there. I will probably send my rods out to Rennsport to get rebuilt. I will update my other thread when I have a little time. Thanks again!
Steve's doing my rods too. He's going to rebush the small end, balance them all end to end and make sure they're all exactly the same length before reaming the bushings. Then ARP rod bolts. I keep telling Steve he needs to move his shop closer to Chicago.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 01-17-2010, 04:27 PM
Carrerax's Avatar
Yep, my rods, dizzy and rockers going to rennsport tomorrow. Not doing ARP bolts though. cant swing it.
Old 01-17-2010, 04:31 PM
Mo money = mo parts
Ok, 12 cans of brake cleaner, 1 can of acetone, 32oz of rubbing alcohol, 1 can of Loctite Chisel, 2 32oz bottle of motorsports simple green, various stainless steel rifle brushes, stainless steel hand-held brushes, stiff plastic and long skinny plastic brushes and about 15 hours of labor over three weekends and I am declaring my case halves and chain housings - clean!
Next weekend will be dedicated to organizing and dress rehearsals of closing the case. I am also moving from the garage back to my workshop to close the case and install the P&Cs. I have to wheel the engine through our carpeted family room (a covert operation ) and over a small threshold, so a fully assembled engine is too heavy on the carpet. Plus, my daughter's bedroom is directly above my workshop so no noisy work before noon.
There are some stains remaining in the case, but no grime. The only way to remove the stains would have been some form of super abrasive. I mean to tell you I cranked on them with brake cleaner and a stainless steel brush, they are happy right where they are.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 01-24-2010, 11:32 AM
looking good..
Bruce
Old 01-24-2010, 12:47 PM
dsmyth's Avatar
Greg What did you decide to do about the pitting on that rocker? I have similar, possibly slightly less on the same one on my 70k 85? Coincidence? Great thread. Inspirational. thanks Doug
Doug
97 C2S 993(last one)
95 993 cab- 85 911 M491
87 944 Turbo- 70 914-6
63 911
Old 01-24-2010, 08:58 PM
Mo money = mo parts
Doug - I am going to replace it with another used rocker. I know this isn't the recommended procedure, but it's hard for me to justify resurfacing both cams and all the rockers for small amount of pitting on a single rocker. I may regret the decision at a later date, but that is my plan for now.
It is interesting that your '85 has the same issue. I have not yet cleaned my cam towers. I haven't done any research yet, but want to see if there is a way I test the spray pattern out of the tube before I clean them. I will let you know what I come up with. Thanks for sharing.
Greg
Old 01-25-2010, 07:30 AM
Woodland Hills, CA
12 Cans of Brake Clean....$40.00
32 oz. Rubbing Alcohol.....$9.00
1 Locktite Chisel...............$15.00
2 Simple green.................$12.00
TOTAL.......$76.00
LABOR.............................Priceless
Machine shop tank clean $45.00
Old 01-25-2010, 08:14 AM
Mo money = mo parts
Believe me, I looked locally for a place that would either tank or have a big washer that would do my case. However, the only local shop that had a tank wouldn't take my Porsche case asking if it had "those studs sticking out of it", and said it wouldn't fit in their machine. Besides, the first pass at removing the heavy grime was pretty fast. It's brushing in all the small crevices that took all the time. My guess is that to have the case reach the same degree of clean as mine is currently would have still required most of the materials and 10-12 hours of time after it was tanked. I would have happily paid $45 for 3-5 hours, but no place local would do it.
Greg
Old 01-25-2010, 09:22 AM
My tanking is a $50 deal
Bruce
Old 01-25-2010, 04:19 PM
Carrerax's Avatar
Any update Greg?
Old 02-01-2010, 11:26 AM
Mo money = mo parts
Not much. At the risk of taking heat for spending even more time cleaning, I spent another four or five hours cleaning the cam towers. I found them really difficult to thoroughly clean. I moved my stand out of the garage to my workshop which is warmer. I also made the tools to hold the chain and rod out of heavy cardboard, which I read on the board someone saying it works great. I also put JB Weld on on the locations Wayne suggests in his book. No one around here sells Loctite 574 which I intend to use on the webs (only), 1194 elsewhere, so I am waiting for my next PP box to arrive for more progress. Also got 1211 for #8. I am going to try to close the case this weekend, but have to attend a memorial service for a neighbor, so may get hosed up.
What's going on with Lilly?
Greg
Old 02-01-2010, 02:07 PM
Woodland Hills, CA
Sorry I didn't mean to ruffle your feathers. Believe me I have done the same thing before. I just thought you might benefit from my experiences. I have learned to pick and choose my battles with motor rebuilds.
Looks good, and really, do keep us posted. Hell, I still learn things everyday.
Old 02-01-2010, 03:37 PM
Carrerax's Avatar
Well, cases are split awaiting cleaning. Heads are done (new valves, springs, Ti retainers, twin plug all by Steve @ Rennsport) cam towers cleaned, new complete Viton gasket set and oem rings (also from Steve). The rods still need to be done and all new bearings ordered (GT3 rod bearings). PMO's should be delivered in a month or so. Im hoping to start putting it together this spring. I also need to get a dizzy made when I get the cash. And to think that this started with "just going to replace 2 head studs and it evolved into a 3.2ss motor with PMO 46's and twin plug....
Old 02-01-2010, 04:07 PM
Mo money = mo parts
Mark - Those are turning out to be very expensive head studs. You won't regret it.
We had 20" of snow yesterday. I thought an hour with the snow blower would take care of it, but it turned out to be more like five hours with the snow blower so didn't get much done.
I finally got the case halves together today. I consider this to be a critical operation, since screwing up means a lot of work and I hate leaks.
I put the thinnest humanly possible coating of 574 on the webs, 1194 on the perimeter, coated #8 o-ring with dow 111, and 1211 on #8 saddle.
1194 is goey and seems to skin pretty quick. I made certain I had a complete, but very thin layer, then hit the starting bell. I snugged up the both ends of the crank, then torque the mains per wayne's book and finished with the perimeter. It took me 35 minutes and I was ready to go and never stopped working. There is absolutely no time to screw around.
The ONLY thing that bothers me is not a lot of squeeze out. In fact, I would say no squeeze out in some places. I just don't see how you could put that stuff on thin and still achieve much squeeze out. It tacks up too quickly for it to migrate very far...imho.
Lots of people said to do this, it was very good advice.
My high-end cardboard rod holders.
The flash makes it difficult to see, but there is 1194 on the perimeter and 574 on the webs.
Lower my case-half with the hoist made it a much more controlled process for a one-man, first-time operation. I was glad I had the thought.
Finished product....well, finished for today.
Greg
Old 02-07-2010, 01:39 PM
Carrerax's Avatar
Looks great Greg! Im jealous!
Old 02-07-2010, 03:48 PM
I like the rod holders....and the 2 block for lowering the case half, looking good
Bruce
Old 02-07-2010, 05:57 PM
Mo money = mo parts
It's been three weeks since my last post. I've been working, but it sure doesn't look like it. I would be embarrassed to tell anyone how many hours I have invested in the project, actually I haven't kept count, but it's a lot. I'm not fast by nature and since this is my first build, don't have the confidence to work quickly. I haven't made any major mistakes, or at least nothing apparent, so if I am successful that I have a motor that runs and doesn't look like the Valdez going down the street, I will attribute that to Wayne's book, the absolute amazing body of knowledge on the board, and taking my time.
Here is the last photo in the workshop before the trip back to the garage. I would have love to done the full assembly in my workshop, but it would have been too heavy to get back to the garage.
I installed the cam towers on the heads, then installed them together on the cylinders. A bunch of people recommended it, and it was certainly easy. So was installing the towers on the heads. I put 1194 between the heads and towers, so I am pretty comfortable that it won't be a leaker. Time will tell. I hope to install the rockers and cams next week, maybe even set the timing.
Greg
Old 02-27-2010, 12:12 PM
dshepp806's Avatar
Very nice of you to share this seriously inspiring, informative endeavor...........
...nice read, bro'.....
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 02-27-2010, 06:20 PM
Greg,
I kind of freaked out myself, about having to carry that motor. And I carry heavy things for a living.
Had to carry my engine out of the basement and up the carpeted stairs,
when it became a short block.
Boy am I glad I did.
Would have been way to heavy as a long block.
Now it's in my living room, wife don't seem to mind. Actually looks nice. Blends in to, wouldn't you agree?
Mike.
Restoring/Rebuilding Yellow Canary '79 911SC
Suspected track car
Old 02-28-2010, 06:56 AM
