2.8L RSR Timing
Dear Gentlemen ,
Last week my 2.8 RSR ish was brought back to life after 15 years [img].
The Engine is built around a Correct 2.7 RS engine with Carrera 6 cams , Weber 46IDA's and Marelli Twin Spark . Now that the beast is up and running i would like to check the Ignition timing and also know the correct Dwell angle or points gap for this spec of Engine . Any Information can only make me happier then i am feeling right now .........
Old 11-24-2009, 01:44 AM
Is it something i have said http://forums.pelicanparts.com/support/smileys/shake.gif[/img]. Surly someone can give me a few hints on the correct setup for this type of Engine . I have purchased the Bible " How to Rebuild & Modify Porsche 911 Engines" but in the back of the book i could not find any Tech info regarding the Timing on a 2.8 Engine .
Cheers Richard
Old 11-25-2009, 01:24 AM
Loose nut bhind the wheel
There are several folks that might be helpful, we are in the week of our Thanksgiving holiday and things tend to slow down here until after Thursday. Wait a bit and try to bump it back up in a few days.
Ed
1970 911S Targa 2.7RS MFI dual plug 10.5:1
1974 260Z SCCA ITS
1998 M3
Old 11-25-2009, 08:50 AM
Originally Posted by Richi996 View Post
Dear Gentlemen ,
Ignition timing is 26-28 degrees at 6K.
I need to look up the dwell settings. Those are NOT easy to do without a distributor machine as the values are different for each set of points.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-25-2009, 08:59 AM
Thanks guys .... I'm sorry ..my Father did teach me that patience is a virtue .
I think the excitement of hearing my engine run has gone to my head .
Have a great Thanks giving ... Family and friends are very important and i will catch up with you all soon.
Cheers Richard
Old 11-25-2009, 10:50 AM
Dear Steve ,
did you manage to find out the gap for the points .I am a little confused as i thought that all 4 points had the same gap value and that the second set are only a back up ? I love the learning curve
Cheers Richard
Old 12-02-2009, 12:38 PM
Walt Fricke's Avatar
It seems dual points serve to increase the dwell angle, and also are overall more robust. The points are set up to open/close at two slightly different points. This site may be helpful:
Mallory Dual Points distributor, how it works, and Why Dual?
You can increase dwell on a single point system by reducing the gap, but at some point that causes its own problems.
Doesn't tell you what the figure you want is, though.
Walt
Old 12-02-2009, 02:23 PM
Thanks for the info Walt ,
i also found a web site with nice pictures and some information regarding Twin Spark Home but values and how to set the points correctly for a Marelli seem hard to find .I think they even have a picture of the Maschine Steve was on about which i have never seen in my life .
Last weekend i put a dwell meter on one side and measured a dwell of exactly 20 degrees ... reving the engine the dwell did not move at all which i guess means my distributor is in good health at least ... I will be at home again this weekend and measure the dwell on the other side to see if they are the same .
Again reading through a few posts some say the dwell is not so important with CDI but its nice to know how to set it on a more complicated distributor.
Thanks again for your replies and time
Richard
Old 12-03-2009, 12:43 AM
