XDI ignition. Where to place the coil packs
I'm embarking on installing an XDI direct fire ignition on my 82 SC. I'm looking for advice, suggestions as to where to mount the coil packs (my thought was to mount them where the CDI box goes). Also, any suggestions where to source plug wires from, I assume that I will need to make them up myself as the lengths will be custom, but I'd like to find one place to get the ends and the spool of wire from).
Old 12-05-2009, 06:42 AM
sjf911's Avatar
What engine/intake? Carbs? EFI? ITB's? CIS? Twin-plug? Distributor in or out? I sourced my wires from Clewett at:
http://www.clewett.com/
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 12-05-2009, 08:48 AM
GaryR's Avatar
Send a message via ICQ to GaryR
Are the coil paks similar to the HPV-1's? With carbs and twin plug (dual paks) I mounted mine here -
Gary R.
Old 12-06-2009, 07:45 AM
Forced Induction Junkie
WERK I's Avatar
Anywhere but on the engine where vibration can damage circuitry.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 12-06-2009, 08:01 AM
Puny Bird
Mark Henry's Avatar
If they have the GM coils you must make sure they are well away from the other electronics. They have more than enough power to cause havoc (EMP) to anything with a chip.
Also they are water resistant but not waterproof.
GaryR has them in the best place for a 911.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 12-07-2009, 04:03 AM
Stock 3.0 CIS intake system. ITB's will happen eventually with EFI, but for now budget can't swing those. Mounting where the pictures show is interesting, but with the CIS it would be hard to get at that point. I presently have a MSD ignition box that is right next to where the stock box goes, it looks like I can mount the packs there in place of the unit, the dimensions are about the same, I just have to change the mounting plate that I made to accommodate the different holes
Old 12-07-2009, 06:26 AM
Puny Bird
Mark Henry's Avatar
Becareful about what I said, can cause some weird issues and you'll be chasing your tail.
BTDT
Old 12-07-2009, 06:48 AM
BTDT
I should be fine.. .The actual control unit will be mounted on the floor behind the passenger seat, so there is at least 3 ft between the only chip containing element and the coil packs. I'm just worried a bit about the length of the plug wires, though the stock lengths will reach where i want to place them, so I think I'd be ok.
Old 12-07-2009, 08:39 AM
Puny Bird
Mark Henry's Avatar
I also had my coils to the one side. I used V8 wires that were way too long, then changed them for shorter wires. It was a total waste of time, didn't make any difference.
This was just a street car.
Just get Chevy wires from the FLAPS, cut off the plug ends and replace them with the used Porsche units.
Old 12-07-2009, 09:01 AM
colescrogham's Avatar
Mounting
You might try this setup I just finished on a 914-6 engine.
Cole
Old 12-07-2009, 09:06 AM
Puny Bird
Mark Henry's Avatar
I say it looks real good, but you shouldn't mount GM coils on the engine due to vibration.
Old 12-07-2009, 09:22 AM
GaryR's Avatar
I even used rubber washers sandwiched in between SS washers to create a slight damper in my setup...
Gary R.
Old 12-07-2009, 09:26 AM
How is this working for you. I thought about making a plate to mount them where the stock coil goes since the distributor would not get in the way. I was thinking of solidly mounting the plate using the stock studs on the fan, and then rubber isolating the actual coil pack. I'd love to have a cleaner mounting, but that would have to wait for ITB's and EFI which ain't gonna happen for at least another year. unless I sell some of the crap I have lying arround
Old 12-07-2009, 12:06 PM
GaryR's Avatar
It should work fine, was just added insurance for me as both my (2 sets of 3) coil packs are mounted to a 1/4 aluminum plate with two brackets - upper mounted through the rear deck, lower bent to clear my strut brace and bolted to the cross frame. I used the rubber on the lower mounting points only. If you absolutely must mount the packs on the engine I would definitely use some thick rubber mounts. Do the grounding with a separate wire.
Gary R.
Old 12-07-2009, 12:12 PM
Jeff Alton's Avatar
not Electromotive, but you get the idea
www.turn3autosport.com
Old 12-07-2009, 03:23 PM
Jeff,
What set-up do you have? I have not seen anything with MSD coils, that looks great!
Lindy
Old 12-10-2009, 07:03 AM
Jeff Alton's Avatar
It is a Microtech ECU. The system has an ignition expansion box with 6 ignitors built in that fire the 6 two pole coils. The coils are GM style that MSD makes as a performance replacement for the GM product. I think Accel makes a similar coil.
Cheers
Old 12-10-2009, 08:32 AM
MrPerkles's Avatar
Send a message via MSN to MrPerkles
Jeff can one signal fire two coils with that set up ?
www.facebook.com/pages/Bournville-Frameworks
Old 12-10-2009, 11:00 AM
Jeff Alton's Avatar
Not normally, I have six outputs, one for each coil, but they fire two at a time. So, two coils fire at a time and I run one pole of each coil to the cylinder that is actually requiring the spark and the other gets wasted....
Cheers
Old 12-10-2009, 12:31 PM
