Are JE Piston Rings Nikasil Compatible, also...
are they JE's own Rings?
Old 02-21-2011, 01:13 PM
Nobody!!!
Old 02-21-2011, 05:20 PM
BURN-BROS's Avatar
If the original application was for a nikasil cylinder then yes JE supplies rings that are compatible. Often, if the size is a stock bore, then they source the original rings. Non-stock bores they source from other makes that run nikasil.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 02-21-2011, 06:36 PM
Hi Aaron... does that mean all JE Pistons that come with rings (regardless of make) are Nikasil compatible?... about to purchase a new set of Pistons, is there any Rings that are better performing than others?
Old 02-22-2011, 01:12 AM
JE rings are Hastings more than likely you can run any material against the Nikasil lining as it is so darn hard. The disaster if it were to occur would be in a soft bore such as Alusil which requires chrome moly alloy. General rule is softer with Nikasil harder with Alusil.
regards
Old 02-22-2011, 06:33 AM
Thanks for reply, so what Rings should I go for for my Nikasil Lined Cylinders... there seems to be a few different variations out there
Old 02-22-2011, 06:43 AM
Why would you want to run anything other than the Goeteze, factory rings that run with nikisil?
Bruce
Old 02-22-2011, 06:58 AM
BURN-BROS's Avatar
regards
The last time I purchased from JE they supplied GOETZE rings for 95mm nikasil applications.
Steve, Make sure you state that you are using nikasil when you purchase your pistons and you will be supplied the appropriate rings.
Burnham Performance
Old 02-22-2011, 06:59 AM
Thumbs up
You can also talk to LN Engineering ,they are very profesional about the je an nikasil . LN Engineering Nickies The Original and Genuine CNC Billet Aluminum NSC-Plated Cylinders
Old 02-22-2011, 07:48 AM
Got ya!
Old 02-22-2011, 09:22 AM
JE has a great tech line too
Old 02-22-2011, 10:05 AM
The company I am dealing with are telling me they are JE Pro Seal Rings... are these ok for Nikasil Liners?
Old 02-22-2011, 10:33 AM
BURN-BROS's Avatar
Bruce
There are many situations where you cannot use them. Non stock bore sizes and thinner ring packs require rings from other sources. There are plenty of engines that run Nikasil now.
Burnham Performance
Old 02-22-2011, 11:40 AM
Aaron... how do you rate the JE Pro Seal Rings?
Old 02-22-2011, 11:45 AM
BURN-BROS's Avatar
No, It's not a one size fits all.
Just call the tech line if you have questions the company you are purchasing from cannot answer your questions.
Burnham Performance
Old 02-22-2011, 11:46 AM
Call Jerry Rauch 714 898-9763 at J&E
Old 02-23-2011, 06:24 AM
the last 2 posts before this one are right on.
if you ask here you get a bunch of variable opinions that will only confuse the issue.
ask a JE technician this question if you want a single accurate answer.
Old 02-23-2011, 07:13 AM
Smart quod bastardus
fredmeister's Avatar
I spoke with Jerry Rauch and he was very helpful. I ordered a set of 98mm Nickies and JE pistons with an NPR ring pak as I thought they might be better than Goetze with regards to sustaining a little detonation. The Goetze seem to be too brittle.
They are compatible with nickasil.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 02-25-2011, 09:50 AM
Irrationally exuberant
ChrisBennet's Avatar
I've use Mahle Racing rings with JE's in 3.4L (3.2 bored out). No complaints.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-08-2011, 08:52 AM
