Twin plug advice
Is there an alternative to the andial signal splitter?
looking for a complete set up for a 3.2/3.4 conversion.
Crankfire systems seem too expensive which leaves me with the mechanical solution. I'm assuming that its a must to have some kind of splitter to ease the burden on the DME system.
Anybody done anything different or should I bite the bullet and buy the Andial one?
Regards
Old 11-04-2009, 02:41 AM
The "big 3" are:
1 - crank triggered systems, the 2 most common being XDI & Megasquirt II with EDIS
2 - a dual distributor system - usually modify a 964 distributor for triggering, and run run 2 CDI boxes & an some electronics to control advance (as the 964 has no mechanical advance)
3 - 12-plug distributor - modify an existing distributor or somehow source an original (and you thought crankfire was expensive). This setup also requires 2 CDI boxes (and associated HW) but doesn't require an advance controller as the distributor has mechanical advance.
None of these options are cheap...
Don't Lift... Don't Lift... Don't Lift
'75 Targa in "Arrest Me" Red, 3.0SC ('79) engine, Bilsteins, Turbo Tie-rods, SSIs into 2-1 M&K muffler... and looking for my next upgrade.
Old 11-04-2009, 04:07 AM
colescrogham's Avatar
twin plug
Long horn has good advice, I would add that Richard Clewett has some nice stuff available using Electromotive bits (I think this is the XDI he referred to) that is not too expensive and works really well.
Best of luck,
Cole
Old 11-04-2009, 04:22 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Supertec has a great twin plug alternative.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-04-2009, 01:34 PM
1966 - 912 - SOLD
lane912's Avatar
that engine is just dead sexy!
Old 11-04-2009, 02:29 PM
If you like that one here's more.
Picture from the new shop coming soon.!!!!
Henry Schmidt
Ph: 760-728-3062
Old 11-04-2009, 02:54 PM
dtw dtw is offline
GAFB
New shop?
Several BMWs
Old 11-04-2009, 03:47 PM
Originally Posted by dtw View Post
New shop?
Patience, Grand opening soon.
Henry Schmidt
Ph: 760-728-3062
Old 11-04-2009, 03:55 PM
Sorry Henry... I forgot you had that. I guess #3 should have included "buy a new 12-plug distributor"
And those are purdy
Old 11-04-2009, 05:04 PM
EdE EdE is offline
whats this kinda thing cost?
Wild Porsche Engine
Old 11-04-2009, 07:46 PM
+1 for the Supertec twin-plug distributor.
That 3.5 twin-plug MFI engine is in my garage
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 11-04-2009, 10:48 PM
3 restos WIP = psycho
kenikh's Avatar
Wild Porsche Engine
As they say, if you have to ask...
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 11-04-2009, 11:21 PM
Wild Porsche Engine
There are so many ways to build a high performance engine. Case in point, the "Wild" engine is a 2.8 short stoke built on a new old stock RSR case. Finding that case is like looking for a unicorn.
You also have many different options for case, rods and induction.
The short stroke 2.8 is a great engine especially for a long hood platform So building them offers great rewards.
Just to give you some idea about price, a base using a 3.0 turbo or Carrera case would cost around $15 K. Add to that $3 k for twin plugging, $6K for modified production MFI and you start seeing a trend.
If you want Ty rods add $2.5K. Ty valve $1.2 K. Built using our new slide valve system add $12-$18K depending on the pump.
If you want one built using a 3.0-3.6 case you will need a Supertec SuperCrank and that will add another $3k or so.
Please understand these are just general prices. If you are serious about building one of these gems we will be happy to negotiate something that fits your budget.
That said: if your budget is $10K we will help you secure proper medication.
Henry Schmidt
Ph: 760-728-3062
Old 11-05-2009, 08:19 AM
These days, I have to ask the price of a "Happy Meal".
Henry Schmidt
Ph: 760-728-3062
Old 11-05-2009, 08:27 AM
Jeff Alton's Avatar
Henry,
Have you considered adding a boss for and electronic (bosch type) injector to your slide valve offerings? Then folks could use them with a modern ECU....
Cheers
www.turn3autosport.com
Old 11-05-2009, 05:59 PM
Originally Posted by Jeff Alton View Post
Henry,
Cheers
We built three slides. One was built for MFI and the other two can be used for MFI or EFI. We will convert the system to suit the buyer. The magic to our system is that the manifold base bolts on and can easily be modified. We can even make a 3 bolt base for a 3.6 head. Add a generic fuel rail and it's done.
We can change the port size to suit the application as well.
We also have stacks designed for use with an air filter housing for the daily driver.
Henry Schmidt
Ph: 760-728-3062
Old 11-05-2009, 06:52 PM
Jeff Alton's Avatar
Nice!!!!
I am wondering how much more power one can expect with slides vs standard ITB's with a throttle plated...
Cool.
Cheers
Old 11-05-2009, 09:52 PM
Wer bremst verliert
JohnJL's Avatar
Cool pics and bits.
If you are intent on keeping your DME then I believe the Andial or similar box is your easiest choice.
Adapting an EDIS system to fire from your DME might actually be the cheapest.
If you make the leap away from the DME then you have even more options like Henry's or JB Racing's twin-plug distributor. They are both designed to perform both the triggering/timing side as well as the spark distribution function. You may be able to retain the DME's triggering of the spark but the distributor's firing. I'm not sure about that. If you go the twin-plug distributor route you need a pair of coils and a pair of MSD 6 boxes also (add ~$400) plus fabricating/adapting mounting panels.
I dont know what an andial box goes for. Henry can quote you a price for his distributor, JB's cost me around $1250. The parts to do it from EDIS would be about $150.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 11-05-2009, 10:04 PM
To expand alittle.
I wanted to keep the DME at this point.
I have sourced a 964 dizzy, was thinking about the Andial splitter so what else do I need to make it all work?
Db
Old 11-06-2009, 01:36 AM
Originally Posted by JohnJL View Post
Cool pics and bits.
The cost for one of my distributors is right around $2,200.
You only need one MSD but you will need two coils.
We mount the single MSD box under the drivers seat to keep away from the RF signal generated by the plug wire and it also keeps it clean & dry.
We mount the coils on the relay board, removing it from the fan housing to isolate it from engine vibration.
The other benefit is a clean engine bay.
Henry Schmidt
Ph: 760-728-3062
Old 11-06-2009, 07:01 AM
