engine stand
Can you use a regular engine stand to hold a 2.2 engine? Do you need an adapter
regular engine stand yes
holding tool yes What part of NC?
Peppy 2011 BMW 335d 1988 Targa 3.4 ![]() 2001 Jetta TDI dead 1982 Chevette Diesel SOLD
You can hold almost 911 engine with a standard adjustable adapter.
When it comes to splitting the case, the standard Porsche/VW tool works best in my experience.
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
Location: the bluest city in the bluest county in the bluest state by the bluest ocean...did I mention the blue skies???
I used a factory style yoke that bolts to one half of the case & allows a complete rebuild plus room to install the flywheel/clutch & Press plate.
I had the yoke plugged into a stand that's avail at most chain "auto parts" (china outlet) stores. It's the one with two horizontal legs for the rollers & one vertical for the yoke receptacle. It was the most "expensive" @ $90 ish but....much more stable then the single "T" foot style &....you can slide a floor jack right in under the middle of the engine to remove it from the stand &....it's strong enough to rebuild a Detroit Diesel, if you need to. See if you can "rent" a factory style yoke from a fellow Pelican'er.....for a case of ???? Brad Penn, Sam Adams, Johnny walker, SWEPCO ????? Good Luck
Greg....PCA, 356 Registry, 912 Registry 1977 911S Targa with 3.2...1960 T-5 coupe 1968 912 coupe, that's 32 P-cars, so far... 1990 Chevy 4x4 2500 pickup (with 255K & still rockin') |
Author of "101 Projects"
The adapter is preferred. The 911 engine case has a lip on the outside that makes effective mounting of a generic engine stand difficult and perhaps dangerous. Later model engines like the Boxster (M96) don't have this problem.
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
I have to agree with Wayne. Get the right engine yoke. I am in the middle of a rebuild. I thought I could save 100 bucks by buying a 5 arm yoke from VW Alley. The quality of the yoke is good but the fit was not really suited to the Porsche engine and I had to re-drill mounting holes. The flat mounting surface places a lot of pressure on the flange on the flywheel case. The flat mounting surface also makes installing / removing of the flywheel impossible. I will get through the teardown with what I have, but I will not attempt the rebuild with the yoke I have. So my cheap solution will wind up costing me $300 rather than $200.
I am all about saving money where you can, which is why this is such a good site. So, my personal experience is that the yoke should be specific to the Porsche. Seth |
Drive it like u stole it.
+1 buy the correct yoke! I also recommend a stand with 2 front legs instead of the single center leg. It is much more stable when the motor is fully assembled. I am sure plenty will say, and have used a single front leg stand, but I have used both and there is a BIG difference IMHO.
____________________________ Bill Jones Jupiter, FL 77 Euro 911 3.0 Wide Body - under construction http://www.flickr.com/photos/rennsport/collections/72157618856489537/ |
I once saw a Lend Lease (US Army) to Russia mechanic rebuild a 1952 Packard engine with little more than a pair of pliers, a crescent wrench and a few worn out sockets. However, using the correct tool for the job is preferred. Get the correct yoke.
Old Tee all 911s sold |
Addicted to Racing
Engine yoke is prefered, but not mandatory.
I notched the arms of my engine stand to clear the lip and it has served me just fine. I have a yoke now, but if you are just going to do this once every 5 years, modify a standard one. Thanks Ed
Check out the parts for sale: http://www.demonspeedmotorsports.com PCA National & NASA Instructor, NASA GTS & PCA GT Class Racer. See my list of current cars in my garage. |
