Eye of the Toiger
matty74's Avatar
Damaged Case what to do??
I have a 3.6 motor from a 98 993 which took a hit from the side, the case sustained some damage the flywheel sensor mount broke off, the rest of the case is OK, but I don't have the piece that broke off.
Now my problem is that I want to run efi and i can't use the flywheel sensor for RPM's, this means that I would have to go with carbys or find another way to count rpms for my efi.
I'd rather not have to purchase another case. Advice appreciated
Matt
http://www.aircooled.com.au
1973 911 RSR clone powered by 77 3.0 turbo
Old 01-03-2010, 09:11 PM
Matt,
You can use an EFI crank position sensor and a special rear pulley to do the job. Clewett can fix you up.
No worries, mate.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 01-03-2010, 09:35 PM
Certified User
billjam's Avatar
Matt,
I have just been through this with a damaged 964 case.
It had a crack at one of the gearbox studs - looked like the engine was dropped by PO on the stud (which was badly bent).
I got it welded up by Head Exchange in Perth. They vee'd out the crack and welded it up, then installed a thread insert - looks like new. Worth a try at $150, compared to $000's for another case.
I am sure there are similar shops over your way that specialise in alloy welding. I used Head Exchange because they were already doing my guides and they are regularly welding up alloy heads.
If you know what the missing piece looks like, I would fab a new part in aluminium and get it welded on. It isn't a structural piece so you shouldn't have any issues.
Be aware that the cases have some magnesium content, so they are not easy to weld.
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 01-03-2010, 09:41 PM
Eye of the Toiger
matty74's Avatar
awesome fella's what a relief, I'll get one of thos nice clewitt pulleys.
I noticed he has a cam sensor what is that exactly used for?
Another question, if someone has seen this done, I was told if I used carbys and did not need a sensor on the flywheel I can just bolt on a 3.0 9 bolt flywheel to mate up to my 915. Is this correct or must I invest in a conversion flywheel.
Old 01-03-2010, 09:45 PM
Cam position sensors are used in sequential FI systems so the ECU knows which injector tor fire,...
For carbs or MFI, we use a 9-bolt flywheel or its alloy equivalent. You'll need the right clutch package to use with the 915.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 01-04-2010, 12:17 AM
