Try not, Do or Do not
Mikes 3.5
How I spent my thursday morning.
Supertec built this 3.5 Motronic engine for Mike G last thursday while Mike watched and took these pictures. The car is an 88 3.2 Cabriolet. The engine has LN Nickies 100mm, JE piston 9.8:1 and DC Super Cup cams. ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
![]() ![]() ![]() 3:30 and Mike's off to catch his flight home. ![]()
Single or Dual Plug
Is that a single plug setup? The heads appear to have one spark plug.
1987 Carrera MoTec 3.8L Transplant, 993TT Brakes 2006 M3 Competition Package 2007 997 GT3 - SOLD |
Thanks for sharing.. cool looking!
yes
Single plug
May I ask why you chose to go with a single plug setup in a 3.5L motor?
Thanks Mark
Single plug
Thanks Mark
Bang for the buck is almost silly. This a street cabriolet for heaven sake.
Todays progress:
Very clean....nice work.....
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
going 3.5, was there any concerns around using the SSI's as distinct from a larger exhaust choice? I thought the SSI's were considered as a little to restrictive for a motor that size ?
88 carrera |
In a perfect world a slightly larger primary might be desirable for higher end operation but for the purpose of this exercise, the SSI seems like the best compromise.
I'm here to cause trouble
Nice! All that gold plating makes it look like P-Diddy's engine!
![]() JB
'86 Carrera Cabriolet '73 911T Sporto (RIP) '90 Miata LeMons Contender! '71 Datsun 510 (RIP) '67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP) '62 Plymouth Valiant '60 Ford Galaxy 500 (RIP) |
Yo Jimbo, You aint getten up in my grill and dissin my bling, is ya?
very nice. Any HP and torque estimates ?
88 carrera |
I try not to play the horse power prediction game but I would guess 265/300.
But the truth is, unless you're willing to change parts "you get what you've got".
265- 300 Wow !. Regardless of what the final number is it will be strong motor and a great ride.
I have to admit though that I get confused with how successful these 3.4 and 3.5 upgrades are in increasing power from a 3.2. If a 3.6 with higher compression puts out 250 HP, i am always baffled that a base 3.2 upgraded to a 3.4 or 3.5 can exceed what a 3.6 puts out so easily?
88 carrera |
Better exhaust and better cams are the key as well as the higher RPMs achieved by these smaller engines.
BTW: that's 265 hp 300 ft/lb of torque
