Are these head studs ok to use?
Could these be used again, or do they need to be replaced?
a.k.a. G-man
I would replace them.
What are they, Dilavar, steel, OEM, Aftermarket??? The markings/scratches on them would have me worried. Raceware, ARP and Supertec make headstuds that are very very good!! (I ordered Supertec studs, extremely strong, race proven and not expensive IMO) Henry Schmidt from Supertec and Steve@rennsport will probably chime in...
Сидеть, ложь, Переворачиваться |
I wouldn't use them in any engine I do,......
![]() Henry???
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
I would say with the stress risers, surface metal compression, and damaged threads created by visegrips or a pipe wrench on those, they are junk.
you can always use them for storing washers. |
Try not, Do or Do not
Those studs look like plain early steel studs with damage from a brutal encounter of the apprentice kind. I would probably chuck them in the waste bin.
I've said about all I'm going to on the head stud issue, at least for now. It hurts my head..... ![]() Oops I logged on under a friends log-in. Sorry
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
3.4 Bigger is better
Welcome to the board. Pictures are always good so we can see what your working on.
![]() Unanimous decision, even with the pro's chiming in. Don't use these! Go factory steel or Supertec head studs.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport Last edited by 88-diamondblue; 02-24-2010 at 05:33 PM.. |
abit off center
You can use them as on oversize stud if you have some really buggered up exhaust head stud threads, use the 10mm head stud thread in the head and thread the shaft 8mm
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Just messing with you.
abit off center
ok guys, got it. thx.
Striker, listen, and you listen close: flying a plane is no different than riding a bicycle, just a lot harder to put baseball cards in the spokes. Looks like I picked the wrong week to quit drinking. There's no reason to become alarmed, and we hope you'll enjoy the rest of your flight. By the way, is there anyone on board who knows how to fly a plane?
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
Constitutional Liberal
I can fly this thing but it's a bad day to quit smoking crack............
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell |
