Putting Everything Back together
I've got my 1979 911 SC engine and transmission back in and was re-connecting all the lines and such. Before the re-build there was one vacuum line not connected and a couple of wires had been cut or not connected, but the car was running.
Does any one know
1) I have two wires (see picture) that come out of the wiring harness just before the 12 pin plug, one is Yellow and the other is Red/Black. What does this go to?
2) I have four vacuum lines, a) Vacuum limiter/thermo valve, b) WUR and C) Distributor. What does the fourth one go to ? should I just plug it?
dog
Old 02-22-2010, 10:32 AM
red and yellow goes to the sensor on the left chain box cover. Its the cold start injection temp switch
The vacuum line goes to the little pod between 2 and 3 runner
Bruce
Old 02-22-2010, 04:56 PM
Bruce
Thanks again for coming to the rescue.
The pod between the 2nd & 3rd runner is my WUR and I have 2 vacuum lines already on that, one from the thermo valve and one directly off of the throttle body.
anything else need vacuum?
Old 02-23-2010, 05:25 AM
Thumbs up Go Here and click Vacuum Diagrams
Jims Basement:
CIS Primer for the Porsche 911
Shane
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 02-23-2010, 10:00 AM
I was talking about #24 in Shanes link gets vacuum lots of times the pod has been removed
Bruce
Old 02-23-2010, 10:24 AM
There is suposed to be a comma between vacuum and lots..or even better, a period.
I was talking about #24 in Shanes link gets vacuum. Lots of times the pod has been removed.
Bruce
Old 02-23-2010, 04:14 PM
