Putting Everything Back together
I've got my 1979 911 SC engine and transmission back in and was re-connecting all the lines and such. Before the re-build there was one vacuum line not connected and a couple of wires had been cut or not connected, but the car was running.
Does any one know 1) I have two wires (see picture) that come out of the wiring harness just before the 12 pin plug, one is Yellow and the other is Red/Black. What does this go to? 2) I have four vacuum lines, a) Vacuum limiter/thermo valve, b) WUR and C) Distributor. What does the fourth one go to ? should I just plug it? Thanks dog
red and yellow goes to the sensor on the left chain box cover. Its the cold start injection temp switch
The vacuum line goes to the little pod between 2 and 3 runner Bruce |
Bruce
Thanks again for coming to the rescue. The pod between the 2nd & 3rd runner is my WUR and I have 2 vacuum lines already on that, one from the thermo valve and one directly off of the throttle body. anything else need vacuum? |
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS Last edited by snbush67; 02-23-2010 at 10:04 AM.. |
I was talking about #24 in Shanes link gets vacuum lots of times the pod has been removed
Bruce |
There is suposed to be a comma between vacuum and lots..or even better, a period.
I was talking about #24 in Shanes link gets vacuum. Lots of times the pod has been removed. Bruce |
