totle's Avatar
Valve stem seal - teflon og rubber (viton) ?
Which are the recommended valve stem seal to use.
Teflon
Or the rubber, viton one
Old 03-01-2010, 07:13 AM
abit off center
cgarr's Avatar
I like the viton, the Teflon have too much drag on the valve stem for me.
______________________
Craig
G2Performance
Old 03-01-2010, 07:36 AM
HarryD's Avatar
Also from a materials standpoint, Teflon tends to creep more than Viton.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 03-01-2010, 08:33 AM
My machine shop likes teflon, he thinks that the viton seals off the oil to much preventing lubrication of the valve stem.
Old 03-01-2010, 09:03 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
I have used the white Teflon seals for a long time on both street and race engines.
Depending on the type of valve guides you use, the seals may be too efficient.
With Bronze guides of the non-knurled variety, I score the inside edge of the seal with a 3 cornered file in one place, and place that score on the top of the assembly ( 12 O'clock) so that oil will get into the guide.
It's a judgement call as to how much of a score to make, small to keep the guide lubed, or bigger to burn lots of oil.
I find with my file (years old) that one stroke does it.
Hope this helps
Bob
Bob Hutson
Old 03-01-2010, 09:25 AM
totle's Avatar
I have replaced the exhaust side with a phosphorus bronze knurled valve guide, the intake side has the original non-knurled one.
Would you suggest different seals for these guides?
I am a bid afraid of scoring too much on the teflon. Too much as you said would be like having an old worn out seal.
Old 03-01-2010, 01:21 PM
+1 for viton. teflon is just too hard and scrapes off too much oil
No physical quantity completely explains its own existence
Old 03-01-2010, 02:01 PM
Walt Fricke's Avatar
Why bother with seals at all on the exhausts? Not much negative pressure acting on them, is there? And the oil has to go uphill.
Old 03-03-2010, 01:03 PM
abit off center
cgarr's Avatar
If you leave the exhaust seal out then you want to complete the mod!
Craig
G2Performance
Old 03-03-2010, 01:53 PM
Is that the 935 modification? Goes from the intake valve spring area? But through a hole in the exhaust guide? To help cool the exhaust valve?
Old 03-03-2010, 03:06 PM
abit off center
cgarr's Avatar
The passage from the intake has not been milled yet, have you tried it? this is just a mock up head for the jig.
Craig
G2Performance
Old 03-03-2010, 03:28 PM
Max Sluiter
Flieger's Avatar
Yes, goes with a finned guide.
Old 03-03-2010, 03:29 PM
Flieger - ever since I first read Anderson in the 1980s I have wondered where that extra oiling passage goes. I can see that it takes some of the oil that accumulates in the intake area, and sends it by gravity down somewhere toward the exhaust.
Where the guide with the finned upper part is.
Your picture of the guides makes it appear that there are two crosswise holes in the exhaust guide, one down in the cylinder head part, and one in the protruding finned part. Is that so?
So the drilling takes oil right into the heart of the guide bore?
A guy would have to be very careful with the Loctite 574 with this setup.
Tricky to miss the stud and have the drilling meet the hole in the guide. Or is that a guide which was pulled out, and the drilling is done in situ? And the drilling passes under the bottom of the stud?
I have wondered why the open groove angles, rather than running down the center. Because that stud is in the way of a mill?
I'm not sure this is something I need to try for a normally aspirated engine, is it?
Old 03-03-2010, 06:33 PM
Max Sluiter
Flieger's Avatar
Its not my photo. You might find the answer here: Reseal for sure, Top end machine work? K27Turbo rebuild?
Old 03-03-2010, 08:49 PM
Lite75/LSD seems to be the owner of the head in the picture, and said the drilling goes midway down the valve guide. Which is about the only place it could usefully go, because the exposed part of the guide - the part finned in the 935 - can't be reached through the spring shims and cup. If the finned part has holes, doubtless that is to get yet more oil to the valve stem. Just the opposite of what valve seals do!
Old 03-03-2010, 09:59 PM
