LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average.
Super Moderator
cstreit's Avatar
That certainly does sound like fun Henry. Is there even enough seating surface on the 3.0L case to fit a cylinder that wide?
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 03-15-2010, 01:55 PM
Jeff Alton's Avatar
Originally Posted by Henry Schmidt View Post
Sorry it took so long to get back.
I have no idea what kind of power/torque 66 x 105 would produce but what a hoot to build it. I will say that 8200-8500 rpm would be possible and given the correct port and cam configuration I would think you could produce good power from 4500.
NO worries on the time frame!! I have a bunch more questions!
Hmmmm, 66mm counterwieghted crank I presume.
What size ITB and Exhaust primaries would you run?
Compression- 11.5:1 or higher (race fuel only)
What sort of cam in this beast?
How would 3.2 heads work in this engine?
You have tweaked my curiosity on this one!
Cheers
www.turn3autosport.com
Old 03-15-2010, 04:10 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Talked to Charles @ LN and he says we could put 102 in an SC case.
102 X 66mm =3236 CC.
To run 105 you need a 964 or 993 case.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-16-2010, 08:13 AM
Hmmmm, 66mm counterwieghted crank I presume. see picture
What size ITB and Exhaust primaries would you run? If the goal is 8500 I would think 50 mm into a 41-42mm port & 1 5/8" primary
Compression- 11.5:1 or higher (race fuel only) I would think 11.5 would be plenty
What sort of cam in this beast? [color] DC90 [/color]
How would 3.2 heads work in this engine? sure
Cheers
Supertec Super Crank
Note the lightened crank throws and hollow rod pin. This cranlk is designed to run the GT# Pankl ty rods. The are race tested at over 9000 RPM
Henry Schmidt
Ph: 760-728-3062
Old 03-16-2010, 08:26 AM
Jeff Alton's Avatar
Henry,
Can you shoot me an email or PM and we can discuss the $$ for the crank and rods?
Old 03-21-2010, 10:13 PM
Max Sluiter
Flieger's Avatar
The supercrank is 66mm stroke? For some reason I thought it used the GT3 stroke.
Old 03-22-2010, 12:15 AM
Henry,
Hi Jeff
Contact me with a regular email address and I'll send you the info. Or call me
8-5 PDT T-F
BTW: The GT3 rods have gone through the roof. Porsche "gold" is always on the rise.
Henry Schmidt
Ph: 760-728-3062
Old 03-22-2010, 09:09 AM
Head416's Avatar
Stumbled across this thread... very interesting!
Any updates?
Aaron
'81 911SC RoW Targa
Old 10-26-2010, 02:53 PM
yep, im slow in the head
carslutt's Avatar
Send a message via Yahoo to carslutt
wow lots of good info, did any of this planing get put into actoin?
1978 911sc Targa - CNC plasma/router cut parts, tig welding, sheet metal work, VAG-COM, LM-1. let me know if u need something
Old 10-26-2010, 04:45 PM
UNDER CONSTRUCTION!
carrera turbo's Avatar
just listening and learning
Sometimes the first thing that comes to mind should be the last thing that you do!
Old 11-05-2010, 12:20 PM
ONQRACIng's Avatar
I am switching from a CMW Stroke crank (77.5 STROKE from a ground 3.0 crank) with custom rods (130mm) and 100mm to a GT3 crank (76.5 stroke) and custom rods(131mm) to get back to the 3.7 I had, maybe a 3.8?.. $1800 for the crank is much better than the 4K for a CMW Billet, which due to the offset grind, can and will crackout.... Just need to figure the rod lengths..
Old 11-08-2010, 03:26 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
searchin for a "what to do to my motor next" and stumbled upon this thread. Whadda tease. it gives me wood. Anything get built?
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 11-16-2010, 11:11 PM
ONQRACIng's Avatar
We have our GT3 crank now, and will be ordering custom 131mm rods, either Carrillo, Cunningham, or R+R, depends on weights. Anyone else doing a similar build?
Old 01-08-2011, 05:54 AM
Jeff Alton's Avatar
Our project changed directions, motor is gone, had a HP twin plug 3.0 turbo motor, but it is still on the stand and likely to be parted out...
Cheers
Old 01-08-2011, 08:21 AM
