Jeff Alton's Avatar
What sort of power and torque are you seeing out of 2.8 with the sprint cam, assuming carbs or MFI and not slides?
Cheers
www.turn3autosport.com
Old 03-03-2010, 06:06 PM
Walt Fricke's Avatar
Kenikh
Actually, the 8mm stem valves I have weigh less than stock 3.2s do. And intakes only 6g more than the stock 2.7s I have been running. Ti retainers, of course.
Sounds like I should add the RSR Sprint grind to my list of candidates, along with the GE100, the Webbcam 171/149, and something from Camgrinder.
As to dyno sheets on Henry's 2.8SS, I think many have asked, but none have answered. Perhaps all will be revealed in Excellence. You can't fault an engine builder for holding some of his information back.
Walt
Old 03-03-2010, 06:36 PM
Try not, Do or Do not
Henry Schmidt's Avatar
The 2.8 Slider was built over seven years ago and I no longer have a sheet on it.
Sorry guys
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-04-2010, 07:44 AM
3 restos WIP = psycho
kenikh's Avatar
Originally Posted by Walt Fricke View Post
Kenikh
Walt
I'd recommend doing what I do with every engine build: call John Dougherty.
When I need a cam, I tell him:
  • My bore and stroke
  • My static compression
  • Type of heads/valves/retainers I prefer to use
  • My port specs
  • My induction type
  • Where in the powerband I want to make peak power
He'll then give you a laundry list of stock and custom grind cams. He will work with you to tweak lift, ramp speed, lobe spacing and durations to create a cam perfectly tuned to the details you give him.
For example, when I was building a 2.3L ST inspired motor, told him I was OK with using Ti retainers, wanted 'E' like torque and 906 top end power...a tall order, given I wanted 100 HP/L potential around 8000 RPM with grunt. I mentioned '69S heads, CNC port work @ 39mm I/E and asked him to build me a dream camshaft.
He custom ground me a set of DC44s on 102 lobe centers...this was before they became a regularly stocked item on his site . These cams ended up being EXACTLY what was specced: Velvety low-end torque, with the engine going completely bonkers from 4500 RPM to 8000 RPM redline (peak HP falloff ended up being exactly at his estimated 7800 RPM).
The 2.25L motor made...drum roll...225 RWHP on its first dyno run, with a torque band that an 'E' motor of similar displacement would be envious of and top end power that is nearly the equal of a 906.
Call John (aka "The Magician")
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 03-04-2010, 08:32 AM
kenikh's Avatar
Cheers
One car I know of got 249 RWHP on 46 PMOs, but a restrictive muffler and exhaust was a limiting factor, as was jetting and timing when the dyno run was completed. The car runs stronger now, but has not had a dyno run since the latest tuning.
Today, it feels like an honest 275 RWHP, which is in line with Henry's quoted 300HP for the Red Sled, given the other car's induction and exhaust disadvantages:
Wild Porsche Engine
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 03-04-2010, 08:42 AM
GE 80 vs 906
Old thread, I know. -but maybe someone can share his opinion with me on the best cams for my engine.
Ok, the choice is not to big as I only have two cams to choose from . GE 80 and 906.
My engine is a 3,0 with 10,3 CR, 41 mm inlet port, standart SC Valve size, headers, open exhaust, ti-retainers, Eibach springs and MFI with 50 mm butterflies. I use the car for tarmac rallyes...
Many thanks, Malte
Old 12-16-2013, 12:10 PM
forgot the twin plug and 102 octain pump gas...
Old 12-16-2013, 12:12 PM
camgrinder's Avatar
Many thanks, Malte
the 80's are better than the 906's.
John Dougherty
Dougherty Racing Cams
Old 12-16-2013, 12:15 PM
Thank you very much for your fast answer!!!
Old 12-16-2013, 12:21 PM
MFI Adapter
I have another question...
Is the part I need to connect the mfi drive with the camshaft an original part? Difficult for me to explain, but attached is a pictore of how my camshaft end looks like. And I think I need a kind of adapter for this???
Thanks, Malte
Old 12-17-2013, 02:06 PM
camgrinder's Avatar
Yes you will need an extension out the back of the left side cam. I make them, but they are rough on the outside dimension. I bolt them on and grind them concentric to the rear bearing journal. (less likely to leak)
John Dougherty
Old 12-17-2013, 02:41 PM
Hello John,
thanks again! I just saw by the name that you built the cams I bought (not directly from you).
My problem is not only that the cams are already installed but also that I am in germany.
Is there a chance that you make it without the cam and it will not leak oil, or is it worthless?
Old 12-18-2013, 05:40 AM
camgrinder's Avatar
Hello John,
Those must be 6 or 7 years old? I cant get that type of blank cam anymore. The ones I have now come with the mfi drive. There is a chance I have a used cam here with the same back side. If I do it might be possible to make the drive, unbolt it and bolt it to yours.
John Dougherty
Old 12-18-2013, 06:54 AM
On the parcel is a sticker that you sent it to a guy called Jay Kjoller. There is no date, -I bought them here on pelican some month ago...
It would be great if you can check if you have a used with the same end which you can use for making the gear- otherwise it looks like I am having a problem.
Old 12-18-2013, 07:53 AM
camgrinder's Avatar
I have a sample cam to work with. If you can, please measure the depth from the end of the cam to the inside surface where the drive will bolt to. The one I have here is .240" deep.
John Dougherty
Old 12-18-2013, 08:34 AM
Great! I have 0,250
Old 12-18-2013, 09:30 AM
I just sent you an email with some questions
Old 12-19-2013, 02:01 AM
camgrinder's Avatar
Got it and responded.
John Dougherty
Old 12-19-2013, 07:03 AM
