a.k.a. G-man
Geronimo '74's Avatar
Carrera oilpump in a 2.7
What happens if one would install the Carrera pump in a 2.7 engine without performing the necessary modifications. (Upgraded springs and pistons for the relief valves and oil bypass modification (machining of the oil galleys)?
Is the machining of the case a must? If one does not do this, what will be the effect? No effect/benefit of the upgraded pump or will it have a negative effect?
Not asking this for my rebuild, I have a 3.2 with a new 3.2 pump.
I just would like to know.
Old 03-08-2010, 12:23 AM
Max Sluiter
Flieger's Avatar
The pressure side was enlarged at the cost of a smaller scavenge pump. This means that there will be more oil in the sump when the oil pressure bypass spring is open due to insufficient scavenge flow rate. The oil-bypass mod corrects this by sending the bypassed oil back into the pressure side, which is large enough to handle the flow. This would be mainly occuring during start-up on cold days when the oil is more viscous.
Old 03-08-2010, 01:01 AM
Walt Fricke's Avatar
Geronimo
It would be, well, stupid not to do the oil mod when installing a bigger pump in an earlier engine. Porsche started this with the late 2.7s, which were nothing super special as 911s go.
You can do it yourself with hand tools - a drill, a tap, a screw-in plug, and the parts (springs, pistons, guide tube, etc), which are cheap.
The toughest part is getting a drill bit started at a slant. You need some kind of tool to grind/cut something which will appear flat for your first drill bit so you can get a hole started.
Given the costs involved in having the case apart and getting a 3.2 pump, and buttoning things back up, the marginal cost of doing this has to be very, very low.
Old 03-09-2010, 03:00 PM
Try not, Do or Do not
Henry Schmidt's Avatar
If the bypass mod has not been done from the factory, do it.
2.7 cases had the bypass starting 75-76 model year.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-09-2010, 03:42 PM
