Piston rings for J&E help
I received a set of rings from J&E with my pistons.
The top ring and the middle ring look exactly the same.
Shouldn't the middle ring be channeled or have a step in it?
The set was sealed and one package was labeled top, the other ones were stacked together however I see no difference between the top and middle rings.
Shane
Old 03-11-2010, 06:22 PM
Top and second rings are the same on the Goetze ringset that JE supplies with those pistons. Both are a top radial width of 0.167in and thickness of 1.5mm, iron, taper face, phosphate coated.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 03-12-2010, 03:05 AM
Thank you sir !!!
I may have mixed one of the top rings in with the middle rings when I was checking end-gaps but if there is no difference I wont worry about it.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 03-12-2010, 10:12 AM
