1975 911S engine rebuild question
Hi folks,
I'm considering purchasing a 1975 911S with a rebuilt engine. I've heard the horror stories about the 2.7L engines but this one seems to have been sorted out. My question: The engine has been rebuilt and now produces 220 HP. Will the increased HP reduce the expected engine life? Here's what I know about the rebuild from an email from the seller: "The engine was assembled using all high performance parts…Divalar studs, Timed crankcase inserts, 10.5:1 Nickasil racing pistons and cylinders, oversized oil pump and oil channels, an extra oil cooler, Euro fuel distributor, SSI heat exchangers, pressurized turbo cam chain tensioners, turbo air box pop-off anti back-fire valve, etc. It was balanced/blueprinted and dyno-tuned to produce 220 HP, which is a significant improvement over stock (they were factory rated at 175 HP). It was lowered with all new bushings and mounts and had Weltmeister sway bar and Ferodo brakes added." |
Hi,
The first thing I would tell you is that its VERY difficult to get 220BHP from a CIS 2.7. I would ask about who did the engine rebuild as thats critical to the value of the car.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
The mechanic that rebuilt the engine is Larry Sheldrick in NC.
