Shroud missing?
There is a gap between the oil cooler and the gray plastic shroud shown in this photo, is there a piece of shroud missing? Or is this normal?
Old 04-30-2010, 06:14 PM
What you have is all there is...
Bruce
Old 04-30-2010, 06:20 PM
OldTee's Avatar
Engines that clean don't run well!
Old Tee
all 911s sold
Old 05-01-2010, 07:09 AM
356RS's Avatar
Looks like a rebuilt oil cooler and the top piece was welded in with a little more curve to it and now you have a gap. I'm just guessing from what the picture shows.
Mark Jung
Bend, OR
MFI Werks.com
Old 05-01-2010, 08:52 AM
The oil cooler was worked on by Pacific oil cooler service the receipt did state that some welding was done. I sent it to them for testing and cleaning. What could I use to fill that gap? Piece of aluminum? The gap is 7mm (1/4").
Old 05-01-2010, 01:33 PM
efhughes3's Avatar
Don't sweat it-mine is the same.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 05-01-2010, 06:45 PM
You can pull up on the aluminum to give you the fill you desire.
Bruce
Old 05-01-2010, 06:58 PM
Mine has a strip of rubber glued to it to take up the space.
-Andy
Old 05-03-2010, 04:06 PM
