Shroud missing?
There is a gap between the oil cooler and the gray plastic shroud shown in this photo, is there a piece of shroud missing? Or is this normal?
What you have is all there is...
Bruce |
Engines that clean don't run well!
Old Tee all 911s sold |
Looks like a rebuilt oil cooler and the top piece was welded in with a little more curve to it and now you have a gap. I'm just guessing from what the picture shows.
Mark Jung Bend, OR MFI Werks.com |
The oil cooler was worked on by Pacific oil cooler service the receipt did state that some welding was done. I sent it to them for testing and cleaning. What could I use to fill that gap? Piece of aluminum? The gap is 7mm (1/4").
Don't sweat it-mine is the same.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
You can pull up on the aluminum to give you the fill you desire.
Bruce |
Mine has a strip of rubber glued to it to take up the space.
-Andy
72 Carrera RS replica, Spec 911 racer |
