Andy
Engine build advice.
Hi, i am just about to enbark on my first porsche engine build. my plan is to as follows:
3.0 ltr standard crank standard rods mahle rsr pistons 10.5 to 1 heads with 49-41.5 valves fully ported twin plug GE80 cams motec fuel injection Any thoughts on the horse power ? The engines going in a 74 carrera weekend driver fun car. regards Andy.
1974 Carrera 2.7 Coupe Sahara Beige #100 - A work in progress |
Andy,
I couldn't hazard a guess about BHP since there are far too many variables, but it will do very well provided you do everything right. Heads are the key to HP. Bigger isn't always better,... Airflow and velocity are the keys.I would NOT use OEM rods. Pauter, Arrow, or Carrillo's are much better. You need to do some oiling modifications to the crankshaft, main bearings and case for the engine to live at the RPM range this is capable of. Further, you will also need some close-ratio gears for this combination to perform.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com Last edited by Steve@Rennsport; 07-08-2010 at 11:09 AM.. Reason: More information |
Andy
Hi Steve,
Already have the heads so would prefer to use them. Oil modifications are already done. Need to source distributor and leads; do you sell them? It's a 30mm anti-clockwise rotation. Also, what sort of cost are the rods? Maybe send me a pm if you are able to supply. Thanks, Andy
I'll take a swag at BHP. I think the potential for 250-270 at the crank is there. As Steve says, there are far too many variables and only a dyno at the end will give you the answer.
Craig
1985 911 Carrera (IROC RSR Clone); 2001 Lotus Esprit V8; 1967 Chevrolet Camaro SS350; 2009 Kawasaki Super Sherpa; 2013 Moto Guzzi V7 Stone An understanding wife!
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Here's what you might expect:
Another RSR Clone Project - Dyno Day Same build except I used 46 mm PMO's and a GE-60 cam
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
Andy
Hi Tom
Wow that’s an impressive build and stunning car.
It's a great drive too....Thanks
I'll second that. Great job Tom.
Mark Jung Bend, OR MFI Werks.com |
