| Registered Join Date: May 2010
				83 911SC Fuel line & sway bar help needed
			2-QUESTIONS: 1. Pressure line leak(squirt) found at front of car just above the sway bar (pic attached). Can I install a pressure rated coupler/insert instead of replacing the entire fuel line?? 2. Missing front sway bar bolts & nut that attach right & left brackets to frame. Does Pelicanparts sell those??    | ||
|  05-14-2010, 10:46 AM |
| Registered Join Date: Oct 2008 Location: Nash County, NC.
			I would cut out the leak and use a piece of hose and a shunt tube.  Avation permatex and a couple clamps  should stop the leak.  If it doesnt youre only out a couple buks. The sway bar is held to a clamp with an 8mm bolt and the support that bolts to the body is 10mm reg thread. Bruce | ||
|  05-14-2010, 04:23 PM |
