Spark Plugs for Twin Plug
I am trying to decide which plugs to use for a Twin Plug 3.0 litre with 10.5:1 pistons and GE60 cams.
I think that the plugs in standard engines changed from a Non-projected to projected type in Mid 1978 and I am a bit concerend about clearance.
I am thinking of NGK B8EVG or B9EVG ofr the 14mm plug and using a D8 or D9EVX for the second plug.
I am sure that there is plenty of experience around and there may be a better choice.
The car will be used on endurance rallies in East Africa.
Old 08-05-2010, 07:19 AM
Try not, Do or Do not
Henry Schmidt's Avatar
NGK BKR 6 EKUB
Bosch FGR 6 KQE
Adjust heat range (5,6,7,8) to suit intake and altitude
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 08-05-2010, 07:43 AM
Plugs
Henry,
Thank you
Old 08-05-2010, 10:08 AM
I have the same motor and run the NGKs that Henry lists with no issues.
Lindy
Old 08-05-2010, 01:15 PM
Mark S
Originally Posted by Henry Schmidt View Post
NGK BKR 6 EKUB
Bosch FGR 6 KQE
Henry, could you please explain why one would have to adjust heat range for altitude? I'm going to guess higher the richer so you need a hotter plug on cars with say carbs that don't compensate as well as a modern engine fuel management system?
Old 08-07-2010, 08:25 PM
