Cylinder advise on my 3.0L project
I've started my 3.0L engine project. My core engine is a 78 3.0L. Living here in Ca, it's going to have to pass SMOG someday.
I've been told I should use 3.2L cylinders to bump the power a bit more and still hit my future SMOG pass goal. I know it's not too wise to bore my used 95's to 98's. Should I search for some 3.2 cylinders, to then have Nikasil replated? Or, purchase a set of 3.2 Carrera cylinder cores and have them bored & replated? Finally, will I be able to notice a measurable difference by doing this? Steve |
Max Sluiter
Nickasil typically does not need replating. It is VERY hard. As long as you still see some cross-hatching, they are typically just scuffed with scotch brite to remove any carbon, etc. deposits, then cleaned with solvent.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Steve,
A 3.2 SC engine is a VERY good performer and will last a very long time if its properly done. The difference is quite noticeable ![]() This will not affect smog-compliance. While there are many choices, I would recommend using new Mahle 98mm pistons & cylinders for maximum longevity & durability. Although there are cheaper alternatives, nothing else comes close for those two qualities.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
yep, im slow in the head
when it comes time for me to freshen up my 78' sc i will go to an 3.2 as long as its tuned properly i dont see it having any issues passing smog anywhere. but ive got collectors plates so as long as i keep them current ill never have to smog my 911 again. it is nice though to know if i had to smog the car it would pass.
1978 911sc Targa - CNC plasma/router cut parts, tig welding, sheet metal work, VAG-COM, LM-1. let me know if u need something |
Fleabit peanut monkey
Do the 3.2 p&c's you guys recommend have the same dome shape as the 3.0 CIS pistons or a more conventional dome shape? If I remember this shape makes the air/fuel swirl around delivering a more complete burn.
I am really asking if you can bypass emissions like I can in Ohio on a car over 25 years old would a different dome shape - non-swirly - add performance? |
Steve,
Using 3.2 cylinders will do nothing for you. The cylinders you have are the same size. You can bump the compression with pistons from a later or euro SC. Another option is to go with 98mm cylinders. This will bump you to 3.2 displacement. You could use a 3.2 crank/rods/pistons to get to 3.2 also. -Andy
72 Carrera RS replica, Spec 911 racer |
Thread Tools | |
Rate This Thread | |
