| coolcavaracing.com |
				3.6 vacuum hose help?
			I did post this in the normal forum, but got no answer. So I thought I would see if all the engine experts are hiding here   I have almost completed all the vacuum lines on my 964 3.6 transplant engine, but have two points remaining that I am not sure about. See the red arrows in the following two pictures: Picture 1:  Picture 2:  As these two are the only ones remaining, my instinct leads me to believe that there should be a vacuum line between the two, or I have done something wrong somewhere! The only problem is that the size of the vacuum line required on the two points are not the same size, so I am a bit confused
				__________________ Pål (Paul) - The Norwegian lost in Finland... 1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!) come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing   | ||
|  09-04-2010, 09:03 PM |
| Certified User |
			Good luck Paul, but there's not a lot of action in this forum. I am doing a 3.6 into an earlier car as well and I have been following your threads with interest. Unfortunately, I can't help with your problem though as I am changing the whole intake system to ITBs so my plumbing is completely different. I am currently working through some interesting challenges associated with fitting a 911 engine-mounted oil cooler as I didn't want the extra expense of putting an additional cooler up front. Keep at it.
				__________________ Bill 1988 Carrera - 3.6 engine with ITBs, COPs, MS3X 2024 Macan S Day job ... www.jesfab.com.au Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S | ||
|  09-04-2010, 09:52 PM |
