tadd's Avatar
Inside Centerlube covers
Could anyone post a close up picture of how the seals are attached to the cam box cover on an early car 901/01? I've seen one picture of the mag 906 covers and there seems to be a ring with three screws into the cover but it wasn't a close up.
I have seals and a 901/05 cover that I need to convert. I thought I got lucky and picked up an early left cover (here on pelican) with the hole for the dual fuel pump, but it wasn't center lube! Silly me, i assumed all motors with wobble nut pumps were centerlube equipped. Close but no cigar.
Thanks in advance,
tadd
1967 912 with centerlocks… 10 years and still in pieces!
Old 10-15-2010, 09:05 PM
Tadd
Here you go...
These came off a '65 911 motor with the Pierberg mechanical fuel pump, Solex carbs and center lube cams.
Let me know if you need more detail.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 10-16-2010, 02:59 AM
tadd's Avatar
Tom:
Your brilliant.... Thanks!
The last pic is perfect. I was told the seals were a press fit, then I saw the 906 cover and got confused.
Off to the mill!
Tadd
Old 10-16-2010, 05:09 AM
