getting to a 2.4E engine
i may have the choice of starting with a 2.2T-carb, a 2.2E-MFI or a 2.4T-MFI engine, but want to get to a 2.4E as my final destination. if assuming all 3 engines were in same good condition, (which i'm sure they aren't
), which one is the furthest along and would require least new parts to bring to 2.4 E spec?I would guess the 2.2E, which will need just a 2.4/2.7 crank to make it a 2.4 ?? alternatively, what is the frankenstern of placing E cams in a 2.4T? ooh, a little knowledge is indeed a dangerous thing thanks
Reza Last edited by 1971 911T; 09-29-2010 at 06:56 PM.. Reason: e cams |
Well, the 2.2E MFI engine seems to be nearest to your target. I recently took a 2.4T engine, had the MFI pump rebuilt to E spec ( Gus, Pacific Injection ), had the T throttle bodies re-built to E spec ( Matt, Eurometrix ), replaced the T cams with E cams, Had the cylinders bored to 85mm ( ebs ), installed J&E pistons 9:5.1 ( ebs )and finally installed MSD.
With the 2.2E engine, you've already have the cams & MFI needed. However, you'll probably need to refurbish the TB's & Pump anyway. I don't know, probably a better ? for a professional early engine builder. Also, the 2.2E has E numbers on it's case. Steve 73 911T MFI Coupe, Aubergine |
Home of the Whopper
The 2.4T will also have the lowest compression pistons. No doubt, go for the 2.2E.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
Is a 2.4E engine in green or yellow?
Is a 2.4T engine in yellow or green? |
2.4E shroud is green
2.4T shroud is yellow......the CIS version was black, I think Regards, Al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ Last edited by al lkosmal; 10-16-2010 at 08:27 AM.. |
