neilca's Avatar
Cranshaft plugs
Once you have removed the plugs from the crank, what do you replace the plugs with? I have seen posts that even suggest threading and plugging. What size plug do you use? Looks like the depth of the plug can be an issue blocking the rod passage.
Thanks,
neilca
Old 09-24-2010, 06:30 AM
You may be able to buy them from Ollies in Lake Havasu or make them your self.
Old 09-24-2010, 07:39 AM
neilca's Avatar
Are you suggesting replacing with aluminum press in plugs?
Old 09-24-2010, 02:09 PM
Yes, only you knock them in with Loctitie and a driver. I think about .001 interference
regards
Old 09-24-2010, 02:17 PM
Walt Fricke's Avatar
Tapping is possible, but the friend who did that said it was difficult as the crank steel is so hard. I think he broke/ran through a lot of taps.
I'd think you'd want to loctite in whatever you screwed in, and maybe also pein the edge of the hole a little when done, just in case. Assuming it can be peined.
Old 09-25-2010, 12:22 AM
I had a local shop thread and plug my crank, this shop does this to the cranks when the plugs are pulled. Although they never did this to a Porsche cranks until mine, I advised them that they would need a new tap for each hole as they found out after braking there tap, it added about $70 to the job. They also used red loctite on the plugs. I voiced my concern about the plugs backing out, he told me that they never had one back out.
Old 09-25-2010, 08:06 AM
