1971 911T's Avatar
getting to a 2.4E engine
i may have the choice of starting with a 2.2T-carb, a 2.2E-MFI or a 2.4T-MFI engine, but want to get to a 2.4E as my final destination. if assuming all 3 engines were in same good condition, (which i'm sure they aren't ), which one is the furthest along and would require least new parts to bring to 2.4 E spec?
I would guess the 2.2E, which will need just a 2.4/2.7 crank to make it a 2.4 ??
alternatively, what is the frankenstern of placing E cams in a 2.4T?
ooh, a little knowledge is indeed a dangerous thing
thanks
Reza
Old 09-29-2010, 06:00 PM
Well, the 2.2E MFI engine seems to be nearest to your target. I recently took a 2.4T engine, had the MFI pump rebuilt to E spec ( Gus, Pacific Injection ), had the T throttle bodies re-built to E spec ( Matt, Eurometrix ), replaced the T cams with E cams, Had the cylinders bored to 85mm ( ebs ), installed J&E pistons 9:5.1 ( ebs )and finally installed MSD.
With the 2.2E engine, you've already have the cams & MFI needed. However, you'll probably need to refurbish the TB's & Pump anyway. I don't know, probably a better ? for a professional early engine builder.
Also, the 2.2E has E numbers on it's case.
73 911T MFI Coupe, Aubergine
Old 09-30-2010, 06:19 AM
Home of the Whopper
The 2.4T will also have the lowest compression pistons. No doubt, go for the 2.2E.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 09-30-2010, 11:07 AM
hans1's Avatar
Is a 2.4E engine in green or yellow?
Is a 2.4T engine in yellow or green?
Old 10-16-2010, 07:51 AM
al lkosmal's Avatar
2.4E shroud is green
2.4T shroud is yellow......the CIS version was black, I think
Regards,
Al
RGruppe #669
http://www.x-faktory.com/
Old 10-16-2010, 08:25 AM
