I want to machine my flywheel to take some pounds off. Where would you all go for this and how much? I'm thinking taking 1/2 pound or 1lb off. This is a street car and has a good bite on the clutch so I'm no too worried about slipping the clutch. Also, how much do you guys think is good for a street car?
Thanks, -P
(1) '77 Chassis and '79 SC 3.0 project car (1) '79 911SC 3.0 Widebody SC (1) '15 Ford F-150 4x4 3.5TT Toluca Lake, CA |
Its easier to use a light aluminum pressure plate to remove weight.
Bruce |
Who sells those?
They are the Sachs sport or something like that. Pelican sells them or I might have a used one, pressure plate that is.
Bruce |
For street driving you don't want to use a lightened flywheel.
Alum. Flywheel
Ed 1973.5 T |
I suspect you could buy one of these for less than the cost of machining unless you can do that yourself. This will work fine on a street SC (I ran it on mine for years).
![]() ![]() In fact, I'd make you a deal, as this is surplus to my needs. Walt |
| Tags |
| flywheel , machine |
