3.2 to PMO carbs
It has been over 20 years since I carbed a 3.2. My memory tells me I moved up the stock cams to 2.5mm, can I get a verification on that because sometimes the mind goes weak.
Bruce
Old 11-28-2010, 12:51 PM
just looking for the info....
Thanks,
Bruce
Old 12-06-2010, 05:16 PM
Bruce,
I haven't done this but here are my thoughts. Big port SC motors used retarded cam timing to get power at the top end. Those of us racing carbed SC motors use the retarded settings also for the same reason. 3.2 engines have limited top end power with the standard Motronics due to intake restrictions. If I were to carb a 3.2 I'd retard the cam timing to get more top end. This means I'd set .9 to 1.2 mm with stock cams.
-Andy
Old 12-07-2010, 06:55 AM
prschmn's Avatar
I'd second the 1.2 number
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 12-07-2010, 09:38 AM
