Piston/Cylinder set differences?
Does anybody know the physical differences (and can maybe supply pictures of the piston tops) between the 911 103 928 and 911 103 949 P&C sets for a 2.7? I have run across a new set of each and trying to determine what is best for a 2.7 CIS engine I'm about to rebuild.
Thanks for the help. |
The cylinders will all be the same, nikisil by Mahle
The pistons 911 103 928 are the ones built for the RS in 1973 and continued for the Euro Carrera 2.7 application. These are used with long duration early lift cams and produced 210 horses with MFI The other set is standard pistons with the CIS wave across the piston top made for the 2.7S, 74 to 77 USA. With CIS cams these produce 175 horse. Both are 8.5/1 CR, your purchase depends upon application and engine configuration. Bruce |
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Thanks for the replies.
I'm intending to build a stock motor for durable street use as a "weekend fun car". I have stock heads with CIS cams and intend to use the CIS injection setup. Is there any advantage of putting in the RS pistons if I keep the CIS and stock cams? |
Max Sluiter
CIS pistons have a dome shape to help swirl the fuel/air mixture for better mixing and cleaner combustion. RS are more flat. RS will work worse than CIS if used on a CIS motor. CIS pistons might hit valves if used in an RS spec motor.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Stick with the CIS pistons as these have a swirl-inducing dome designed specifically for these applications.
Thanks for the info! That clears things up quite a bit.
