2.4 CIS Flavored
Hi, I may be looking at a top end rebuild for the very stock 2.4 CIS in my #'s matching 73.5. I am looking for info to maybe "warm her up a bit" if I can get maybe 30hp more with the same drive ability, keeping a low budget and the CIS... I know this maybe asking a bit much but....
Thanks, Ron
Ron 73.5 T 74 R90/6 (Tupelo Honey) 86 Carrera (Plan B) 1987 BMW K100RS Motorsport |
About the best thing to do is put a set of CIS S cams, that wouldnt be 30 horses though. The 2.4 is very limited to keep the exterior of the engine looking stock.
Bruce |
Thanks Bruce, Does the distributor have to re curved to match the cams?
Some mild port work would help, but good work is never cheap - perfect time to do it, though.
What exhaust are you currently using?
Dealer for Cibie & other Period Fog/Driving Lights, brackets, Corbeau Seats, Fuchs, Torque Thrust, Minilite, Coromodora and other Period Alloy Replica Wheels GregGearHead com Ask me about Replica Fuchs (Even Deep 6 & 7R) wheels! |
Stock exhaust...
The car is totally stock The 73.5 CIS has a different spec fuel distributor and the intake tubes are smaller In production 6 month only stuff....
You want to keep the stock visual and there is little you can do without spending doses of money. The engine is most valuable in stock form thats why I mentioned the cams which are inexpensive.
Bruce |
Thanks, I'll look into cams
Leave everything exactly the same, except have the crankcase opened up for 2.7 cylinders. Run Dilavar studs (don't bother with timeserts, your crankcase is still a virgin) and run the 2.7S Mahle pistons and cylinders. I did this on my old 2.4 CIS, and I loved the results. Lots of low end torque, decent gas mileage and not ridiculously expensive, at least in Porsche terms.
Is yours that Chartreuse coupe? |
Yes...But it's Zambezi Green...paint to sample per COA
