SC cams - A direct fit for 930 engine?
I am in the process of sourcing all the parts to perform a top end rebuild on my C2T 3.3 engine. AFAIK this engine is the same as all the previous 930 engines.
Will SC cams go in with no other mechanical changes required?
Do I need to upgrade the springs and retainers if I am staying below 7k rpm?
Do most people buy new factory SC cams for these projects or just source a good used set? I don't want aftermarket reground cams!
Old 12-23-2010, 09:06 PM
Max Sluiter
Flieger's Avatar
You need to fit a drive thingy for the Turbo scavenge pump. I have heard some people use the air-injectioon pump attachment if they are not using smog control equipment.
Old 12-23-2010, 09:08 PM
Interesting. Can you provide additional details?
Any smog stuff that might be lurking under the rear tail will be coming off!
Old 12-23-2010, 09:21 PM
Max Sluiter
Flieger's Avatar
Here you go: Confused on sc cams???
Old 12-24-2010, 12:07 AM
Thank you! That thread has lots of great info.
Does anyone sell new SC-profile cams from billet so I don't have to go the weld & regrind route?
Does my C2T engine have the same air pump and scavenge pump spacer issue that the 930 engine has?
Old 12-24-2010, 08:35 AM
Web Cam Inc. - Performance and Racing Camshafts will grind you cams on new billets or hardweld your cam and regrind it. A friend of mine got a 964 grind on a new billet from them for his 930 and it works great.
It's best to call and talk to Laurie the owner about that.
Dougherty Racing Cams Porsche 911, 930 and 964 camshaft profiles probably does it too but I don't know.
Old 12-24-2010, 10:12 AM
Whatever. The 1964 XLH rear intake cam I had built up and reground in 1982 (factory used to use an XL grind in that location "to make it easier to start" - wow. Just wow.) is still fine, as are the 930 cams Mr. Dougherty re-ground to SC profile for the PO. Dunno the exact mileage - but I've put in excess of 30,000 miles on those in 4 years.
'77 S with '78 930 power and a few other things.
Old 12-24-2010, 02:24 PM
Maybe I should reconsider reground cams.
Who is the most respect supplier in the game?
I imagine that reground SC cams to fit a C2T engine should be a simple request?
Old 12-25-2010, 09:47 PM
Also talk to Dimitri over at Elgin Camshaft or Neil at Performance Developments. These guys will not just sell you a camshaft but will work personally with your engine layout to provide the best possible solution for your particular driving style. They both provide alterations in camshaft grinds instead of just the SC or 964 style grinds that most here jump on.
Old 12-27-2010, 03:39 PM
I have a set of SC cams that are in excellent shape. PM me if your interested. A lot less $ that a re-grind.
Lindy
Old 12-28-2010, 07:36 AM
