haycait911's Avatar
2.4 mfi distributor in a 3.0 case
some details of my experiment. I wanted a better curve than the stock SC dizzy for my webered 3.0. I could have the stock one recurved but I have a bunch of extras and parts laying around. I took the drive gear off a SC dizzy and put it on the 2.4. just drilled out the old pins, found a screw with the right diameter and used the shank to pin the gear. then a center punch to flare the ends. plugged it into the 3.0 case. I'll post running results once I fire it up.
Old 01-15-2011, 02:15 PM
dizzy
The SC rotation is CCW, the early dist is CW rotation. won't work
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 01-15-2011, 05:43 PM
haycait911's Avatar
hi Mike. I think maybe you didn't read my post all the way through. I changed the drive gear on the dizzy to one from an SC.
anyway, after a few of the usual start-up issues, it's running. I need to get it tuned and dialed in then we'll see if the curve makes any difference.
Old 01-15-2011, 11:44 PM
I think what Mike was trying to tell you is that CW and CCW distributor advance mechanisms only function in one direction. So,.....if you rotate the 2.4 distributor CCW, you'll not get any centrifugal advance.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 01-16-2011, 01:28 AM
haycait911's Avatar
oops. never thought of that. feeling a little silly. oh well, back to the drawing board.
Old 01-16-2011, 01:38 AM
rotation
Exactly, We make a billet 6 pin distributor with a magnetic trigger for both rotations, if you like take a look at the website. Steve has used a few of them. They work well and you can change the springs and/or limit the total advance to make whatever you like for a curve.
Old 01-16-2011, 05:17 AM
Or plan ahead and change the crank gear and the 2.4/ 2.7 stuff will all work.
Bruce
Old 01-16-2011, 06:12 AM
