Thanks Walt. Cole, and Bruce.
One of the things I really appreciate about owning a Porsche is the caliber of people that you meet like this or in the PCA clubs. Where else do you find technically astute willing to help folks like this. Well I ordered Wayne's book. I have rebuilt Ford engines, and think I will attempt this. I am inclined to go with the Supertec studs based upon recommendations I have read in this media. I also read ARP are also excellent. Are studs throw away? I mean if I do a top end rebuild and in a few years do the bottom can I reuse the studs? if not it may make sense to do top and bottom now. any recommendations Please. What I am apprehensive about is that I bought this car 2 months ago and I don't know how long the PO drove it like this. I suppose once I start the disassembly I will get a better feeling about the magnitude of the rebuild. As you suggested, read the book, get a plan to move forward. Thanks again. Michael Last edited by roadster49; 02-27-2011 at 06:31 PM.. |
Studs are not like rod bolts, which are generally a one time use fastener. If studs get damaged somehow, then you'd want to replace them. And in this case you are looking to upgrade to a stud which should last a lot longer than the original studs.
In stable: 1980 911SC Targa RoW Guards Red 1969 911E Coupe |
I recently bought a '84 Carrera, while doing a clutch job and adjusting valves found a broken head stud very simular to the one pictured earlier. Being a cheapo and lazy I thought I would replace the ONE broken one (#4). I removed required stuff, slid cylinder up enough to very slowly about a tenth of a turn at a time with heat on the case to get it out and replace it.
While doing other tasks and getting ready to install engine I heard the infamous and dreaded "PING", yep, another one let go. I did a little research, you know, stock, oem, Raceware, ARP, etc. After talking to Henry Smidt on the phone I decided on the SUPERTEC, the only one with a warranty. I have no regrets, excellent product and concidering you get new nuts and washers not a whole loy more than steel. So my advice is bite the bullet and don't do like me and do it twice. You can be careful and slide the cylinders up and remove wrist pin clips and remove pistons in their cylinders. Plus you can really get a good look around and see the condition of things. I lapped my heads when re-installing, I know every one doesn't but I guess I am old school. |
